75 FJ40
HEI Dizzy
2F
External Volt Reg., amp meter type.
6mo old Optima Red Top
Have searched through past threads but am still baffled as to what the problem is. Just installed a new Bosch alternator. Now my amp meter always reads just in the neg. when idling with no load. Increase RPM, no change. Add load and just goes further into neg. Before I change alt, amp meter would indicate pos. charge. At rest the batt has 10.07 volts. Running it has 9.91. Pull the pos cable when running and the engine dies. Checked ohms thru voltage regulator per Toyota manual and ranges were good. Didn't pull apart. This is the only component I haven't replaced yet. Footnote...have been chasing a slow battery
drain for the past couple months.
Thanks for the help guys !!
Mike
HEI Dizzy
2F
Mike
