Charging or Not ?!?!?
Engine Fuse
New alternator, new volt reg., and now it keeps blowing the engine fuse. Have checked and cleaned all grounds and fuse panel !! Any advice would be greatly appreciated.
mike
I am not familiar with that term. Is that your fuseable link? In any case if you are blowing a large current fuse I would have a stout pair of side cuts very nearby. Be prepared for what I call Nuclear meltdown. That is a large gage wire shorting out and acting as a light bulb filament. Very bad. Cut the wire if this happens you could start your vehicle on fire.
You do have a good Volt - Ohm meter correct? And know how to use it?
Step back and restate what you know to be good and bad.
Battery @ > 12.5 VDC -
Is the battery really good? Did you charge it? Load test it with the engine off, turn every electrical device on. What is the battery voltage?
Alt outputs 13.5 VDC with engine running.
New Regulator - Wired correct per the install directions for your particular alternator. Does the Alt have a "field" wire also called a sense wire? Where does it land?
What electric mods have been done to the vehicle.
What fuses have been blowing.
Amp meter still not working? Was it ever? Does it have a shunt or is it in series?
We're not there, you need to feed us questions.
Good luck
BigJim
My SWAG is you have a high current connection somewhere wired wrong. Be very careful of fire.
12.25 volts across the batt. while it's running. 11.8 when load testing.
Yes, the battery is good, I took the one out of my 55 and took the Optima out.
I guess the amp guage is hooked up as a shunt. It has a pos & neg terminal. The large white wire with a blue strip goes to the neg. and the pos. terminal is fed by the pos battery terminal. Only fuse blowing is the second one from the bottom of the panel. It is for the IG terminal, engine and a couple other things. Amp meter used to work but now only shows negative. :confused:
At 12.25 VDC you are NOT charging, unless your battery is severley dead. You say its 11.8 when under a load. OK thats not so bad. Battery is OK. Now why aren't you charging? What about the field/sense wire? The regulator needs to know its time to charge. Where is this wire landed? . I run a 3 wire GM alt and land the sense wire to my aux fuse block that runs all my extra 12 VDC stuff. ham, Chicken talker band, trans cooler, Hella's etc.
Was there an "event" that may have destroyed the diode field in your alternator? Do you have 13+ VDC anywhere when the engine is running?
If you had a large shunt you would be able to determine what the alt is outputting.
Are you certain its all installed per OEM instructions?
BigJim
If you do not have >13 VDC anywhere your Alt or reg could be bad.
Just put a new regulator on today. Had alternator tested the other day at it was putting out 13v on the bench. Don't have 13+ VDC anywhere. :confused:
Out of the box solution
I just had a similar problem at 1AM driving through SanAntonio, TX. Everything had been working fine for the past 10 days and 2500 miles then dim lights and discharging Ammeter. My 40 has two alternators (one for a belt tensioner) with my wiring set up to allow me to swap as needed (both are internally regulated). I made the swap but the problem remained. This led me down a different path. Behind the gauge cluster in the wiring harnass is a factory splice. The white/lightblue wire comming off the alternator doesn't go directly to the ammeter. It along with the same color wire on the ammeter and a third wire going to the key switch are crimped together with small brass crimp ring. During my delima, just wiggling the harnass behind the gauge cluster restored charging. It failed again after I got home which led me to this discovery. I replaced the loose splice ring with a small split-bolt and have had no problems since. I hope this helps.
Leon...
