Ok guys so here's what I just came up with, I think this is as good as it's going to get. If you need anymore angles or have questions let me know.
PM me if you are interested in purchasing this product, I will do a group buy discount.
by tomorrow I should have a bracket you can mount 2 lights on top of each other, also developing one where you are mount a 40" light bar across your hood.
-This mounts to the hood hinge so you will not need to drill any holes or need any hardware.
- Built out of 1/8" aluminum, does not rust, doesn't need paint or powder coat, but I can definitely paint it or have it powder coated.
- I was doing 50mph with no noticeable wind noise.
- It sits flat over the hood because I bent the lines very carefully to achieve this.
- There was very very minimal vibration when I went over a few pot holes at 50mph
- WIRING: I tested the wires, i put the wire from the light under the hood, closed it up and it does not pinch the wire. You can run your wires under the hood without issues.
