Can't wait for you to treat Twin Hills like a half pipe!
what does the red wire connect to..I assume somewhere on the Toyota tach or "t's" into a wire?
The tach does not start smoking if you rev it past 4K
During normal driving it probably never breaches 2000 rpms. 3000 is about the max if you're trying to drive fast.
You have to really mash the motor to go higher than 3K, as it just isn't needed.
It seemed to struggle recovering from the shift, but no more so than the speedo needle bouncing around.
I do notice that the needle bounces with the voltage when my turn signals are flashing. Maybe @TrickyT has a fix?
Look at the big brain on this guy!
You don't even know who you're messin' with here. Nobel prize level stuff, he's not even flexing his muscles.
And, I must say, after spooling this V8 up down his "hood" I can safely say that my 80 will now get a domestic V8 in the future.
Tiny update: TrickyT modified my FJ60 AC amplifier to work without a tach signal. So now I have a 60 amp without the blue knob. It will work at any rpm.
Word on the street is that the modification was simple (though the research to find the fix might finally earn him that Nobel Prize) and he might be doing a write up on the solution in the 60 section.
The 60 is potentially better than the 62 amp because you can control the cut-out temp. Theoretically I could set it at 32.00001 degrees vs the 34 degrees of the 62 amp and spit out some slightly cooler air.
