C.B. antenna location
Spicewood, Texas
Looking for the best location to mount a CB antenna, ware it wont get torn off.
Any info on antenna types is also helpfull. :beer:
Thanks,
Jeff
I have a K40 flex antenna. I have it mounted to a tab welded on the roll cage. It is protected somewhat by the cage. I was told it would be fine there as long as there are no large metal surfaces for it to pick up another ground plane. My SWR readings are very low.
i got mine mounted on the rear quarter panel with an antenna that doesnt stick up taller tahe the roof so it wont get caugh on things. oh its just your radio shak special $15
I've got a magnet mount on the cowl, but the wiring leading to it is less than ideal. I'll be replacing it with a 102" whip (for when the top's on) and a 7' fiberglass (when the top's off), permanently mounted to that useless vent on the cowl. I'll have to insulate the front of the rain gutter, but that shouldn't be too much of an issue.
The best place to mount a CB is in the center of a large flat metal surface, ie hood or roof. The absolute ideal in CB antennas is apparently a long magnet mount whip in the center of the roof of a cargo van for example.
For wheeling, almost all communication is line-of-sight. Perfect ground plane etc is not necessary. I have an aerial clamped to my ARB bullbar with a ground wire running to the body and it works very well, for me. The 40 is bolted to the body just inside the rear swing outs. (No hard top. Both work great for what I use them for.
You want to avoid both any location where the mount is not grounded, and a mount with no insulator. Stud mounts include a plastic disk, this insulates the conductor (which connects to antenna) from the vehicle. If you cannot find a place where the mount will be grounded, you can run a ground wire from the coaxial shield to vehicle ground. The shield is connected to the outside part of a stud mount, so you can just slap a ring terminal on the stud mount in between it and the bottom (other side from antenna) of the mounting surface.
It is hard to describe, but extremely simple if you see it.
I run a soft top year round and drilled a hole in the plate that goes across the back and mounted it behind the spare tire. It doesn't get in the way. I also took a tennis ball, cut a hole in the center and placed it over the antenna. It goes between the back of the cruiser and the spare tire acrrier and keeps it from ratteling.
Had to make adjustments to fit with the carrier closed and so it would not hit the garage door. It is a 4 ft whip ant.
mine had instructions to mount it away from other electrical devices like the engine. i have a 10' stainless steel whip on mine and i can talk to truckers almost 10 miles away. i just fold mine down when it's in danger.
Someone asked about a ground plane. What that is is a reflective "surface" which enhances the ability of the antenna. Even those really tall commerdial AM radio antennas have such a ground plane except it's in the form of wire that runs radially out from the center of the vertical antenna.
Best place to run an antenna is on the roof. If you don't want to carve up the roof then there are some very good suggestions that have already been made.
Cheers,
KC6ZWY
Now Living in Washington State...
