Build 'Brightening' a Fj60
Finally got my hands on something I've been hunting for on/off for a couple months and it's coming from Australia.
Any guesses?
DING DING
2F non-usa carb hat
Come to VC/LA County to get your free beverage of choice.
Crazy Find!
I'll come for some Pappy Van or if that is in short supply we'll have to hit Topa Topa. I'll let you know next time i"m down that way. Need to see your rig in person... Or we can meet in the middle at Solid Axle Summit.
Sweet score on the carb hat. I should buy your stock one from you. I actually managed to run mine over, believe it or not. Got all excited when i got the truck running for the first time and forgot i had placed it in front of the tire and took off for a test drive! :bang:
Question: How did the truck handle the 33x10.50s before you had the OME lift? From the pics it looks like you ran them for a while before you put the lift on. I'm really needing tires, but the OME lift isn't in the cards right now.
I'll keep you in mind but as of right now I plan to hold onto all the factory bits just in case I need them.
The truck was a mess in the handling department early on, so I can't really say how it truly felt with 33s and stock height. The tierods were toast, p/s pump and gearbox leaked like a sieve, blown shocks/steering stabilizer and flat leaf springs. I did put 4,800 miles on the tires up and down the coast and it never gave me a problem before sorting out all the issues. Now that they are all fixed, it's great!
I wouldn't doubt it would be fine, the only true change is that it is slower starting out. I don't really notice as much unless on a steep grade on the road.
Alright, time to do the H55 parts list....
33030-60450 H55F Transmission
33124-36010 Oil Pipe - Nipple
33530-60160 Shifter
31210-60070-84 Clutch Cover
31250-36342 Disc Assembly
90363-52001-77 Throwout Bearing
90363-15004 Pilot Bearing
90311-99001 Rear Main Seal
33548-60020 Nylon Bushing
90913-01016 Flywheel Bolts
Also Terrain Tamer T-Case Rebuild.
Also need to do a run through of all the hardware for reassembly... Here goes another chunk of change.
33530-60160 Shifter
Save yourself some money and get this clutch kit: same manufacturer as OEM except in OE aftermarket flavor:
https://www.amazon.com/Aisin-CKT-032-Clutch-Kit/dp/B008EEXPQA/?tag=ihco-20
Add these too, you will thank me later:
36324-60050 x2
33548-60010
90501-16115 x2
90385-08001
36340-60080
33554-60021
90301-18018
90310-09001
https://www.amazon.com/Aisin-CKT-032-Clutch-Kit/dp/B008EEXPQA/ref=sr_1_1?s=automotive&ie=UTF8&qid=1517448404&vehicle=1985-76-1017-20--9-8-8-4706-1841-3-2-1986-202-1-0&sr=1-1&ymm=1985:toyota:land+cruiser
36324-60050 x2
33548-60010
90501-16115 x2
90385-08001
36340-60080
33554-60021
90301-18018
90310-09001
Wow, that is really helpful @beno i really appreciate it! Funny you send the clutch kit too, i just looked it up earlier and realized the price difference. Everything helps!
Aisin clutch kit is 153.00 at rockauto
