Brakes not working
midwest (iowa)
Just finished rebuilding my FJ40 1971 from the ground up. Last thing on the list is brakes. The pedal will go down about halfway and then something gives and it goes down even further. So the brake pedal feels normal to about the halfway point. It feels like a spring is letting loose at that halfway point. I am thinking my master cylinder needs rebuilt or replaced. I did a disc brake conversion, have my proportioning valve in place, the problem is I can’t build pressure?
My biggest issue with my 1972 LC (original drum brakes still) was a similar brake pedal as yours. Push half way and it would continue to go down, and I had to pump it up. I replaced a brake hose from the Master to the distribution T on the front axle.
The steel hose in place was direct from the master. The new hose I installed added a few curls which gave it more fluid to push. Search under my tag and see my brake adventure. Good hunting.
Boaf
I did not. I put it together just as I disassembled it.
Does that mean you’re using a drum brake booster and master?
4 wheel disk or just front disk? Rear shoes adjusted properly?
You will have to give a lot more details on parts used . First I would watch the cups if a dual cup master and see if fluid is going from one to the other. That would indicate bad seal on the piston.
Front disc rear drum. I wonder what Pedal feels like when master cylinder goes south? Yes it’s a drum booster and master. Is this correct? Possible? So I should recheck rear drum adjustment. I don’t remember loosening the rears.
X2
If you’re still using a drum master, you’ll need to remove the 10 lb residual valve from the front circuit. I, as many others, ran for almost 20 years with no residual valve without any issues... although in theory it should be replaced with a 2 lb valve.
It doesn’t sound like you replaced the rear cylinders, but they can be especially difficult to get all the air out of. I’d adjust them till they are tight to the drums, bleed them till there’re no bubbles left, and then see how they feel.
If in doubt, replace your current master with a new master from a ‘76+ disc/drum Asian master and save yourself some headaches. Then bleed, adjust, and report your findings.
If your rear brakes could use some luv, get some brackets and discs from @Poser, and new calipers from your jobber of choice. Then replace your master with one from an 80 series landcruiser... bleed and forget ever doing another adjustment. Put on your seatbelt... make sure it’s tight... get her up to about 30 mph, and jab the brakes... enjoy being able to lock all 4 on dry pavement... super easily :D
Disclaimer: Before actually doing this, make sure you have a properly adjusted brake proportioning valve in the rear circuit, and most importantly that no one is tailgating you (unless you want whiplash when their bumper is crammed so far under they hit the rear wheels).
I think @bikersmurf laid it out for ya. It sounds like you've overlooked the same little thimble sized problem that I did, described here and here. The original drum booster and MC puts around 10psi of force front and back, and the residual valves slow the rate of release (holds pressure) back into the reservoirs so the cylinders back off properly. Disc only needs around 2-3psi and doesn't need a metered release like that.
If the front residual is still inside your MC, then it won't work right until you take it out. But x3 on purchasing a proper '76+ MC set up for disc/drum and saving some headaches. You'll have to bend your brake lines to fit the top threads vs side. Technically Toyota also made a dual diaphragm booster that should be paired with a disc/drum system. The stock single diaphragm used in an all-drum setup is said (not by me...according to my lawyer) to function okay with a front disc conversion so long as you use the proportioning valve described above.
