I have replaced the front calipers and pads, the rear wheel cylinders, and the master cyclinder. The brake lines were replaced with stainless braided lines prior to my ownership. The booster is still original.
What is happening is on the first push of the brake pedal it goes right to the floor. You can then pump it up and it will hold. It will not fall. There is no leak from anyway. I just re-bleed all the lines today and had no air in the lines. It also kind of sounds like a hiss noise when I push the brake pedal. My question is, is there some other ways to try and diagnose or repair this first pump pedal falling?
