I have no experience of touching up body work or respraying. The little I know comes from watching American Hotrod and Boyd's bodywork shop...
I picked up my BJ40 (with it's cow hide pattern) last week. Whoever painted it must have used household paint and applied it with a stick. Even my untrained eye could see it would need sanding if I was ever to get a good finish. In true Jim Phillips style (not stopping to ask for advice) I got the air full of dust and went to work with the sander.
I am not sure if the result is not quite what Boyd would approve of.
I have used 80 grit sanding discs and then 140 to smooth down further. There is not a lot of rust and the finish is smooth to the touch. I am planning on going over it with some bondo (picked that up from American Hotrod) but just where there are visible dinks. I think I should also rub it with some very fine wet and dry.
Am I going about this the right way? I seem to be going through a lot of sanding discs and they are not cheap (especially the dremmel ones) Is there a trick I might be missing or any advice to be had?
Cheers, Jim
Cheers, Jim
