Boyd Codrington style respray
albee said:
I bought a DVD from www.paintucation.com it has lots of good info and a fourm to ask auto painting questions. I only took mine down to bare metal in the places that needed filler.
a BIG +1. His videos are excellent and they also have a discussion forum where you should go.
I *think* you should prime and then use the bondo. Bondo on bare metal may allow rust to form underneath (check on the paintucation site to double check).
I wouldn't worry too much about the grit you are sanding with now, as I would assume you are going to prime and then block sand the primer (with 4-600) to get it smooth and level but leave enough tooth for the topcoat (like llih and lavarunner said).
Don't let it rust: when done sanding you can use something like Eastwood's metal prep/cleaner. It phosphatizes the surface to prevent flash rust while you do you other preperations.
I found that dissasembling mine and painting the parts and pieces seperately was easier to eliminate overspray, and it really doesn't take that much effort to take it apart. I left the tub on the frame and removed the rest. I could move all the other pieces alone. I used a chemical stripper first and I think it saved a lot of work, and dust. Looks like your getting after it!! It will be worth the effort, especially when you can say "I did that."
pappy said:
Looks familiar.
Since were on the topic of sanding. Always make sure you leave the bare metal with a somewhat rough finish so the self etching primer will stick and seal the metal correctly.
Don't over sand whereby you have a smooth baby's butt finish (polished finish) otherwise the primer will not be able to do it's job and you'll be painting the Truck again in two years.
Small gouges will work themselves out after each application of primer and a sand finish until your ready to paint. A good paint job is in the sanding (hard and wet).
Actually, I didn't sand. I used several disks on my grinder made for paint removal and surface finishing. One was a stiff wire wheel, which left some of the original red primer visible in the pic. The other was a 3M 50 grit Bristle Disc made for paint removal. Several other products were tried, but those two worked the best.
Primers
UNO_RACING said:
Looks awsome!!! One word of cautoion before you paint. Please use a self etching primer on the truck. The extra primer step will allow for better paint adhesion and protect the metal from future rust.
It is my understanding that a good epoxy primer will do just the same as a self etching primer. If there is more on this from anybody please post. Eitehr should be followed by the 2 coats of regular primer sanding between each. THen base coat/clear coat.
