Build BJ74 - new owner, old truck
They can absolutely ship today, we still have 3 hours to get things boxed up before they leave. I'm getting them pricing now.
EDIT: Jason will be calling you shortly. Sorry for the back/forth on seals. I reaaaaaally need to get all those parts added to regular inventory. To be fair we'll sell about 8 of those seals and use about 8 in-house annually, so they are looooow on the to do list. :D
All right got it done, and looks like they’re shipping this afternoon! Glad to have such great vendors around!
Ya good motivation.
Thanks again!
Got a phone call from the machine shop this morning, heads cracked between the valves on cylinder #1. Fuuuuuuuuhhhhhhhk
Really didn’t see that coming, truck hasn’t been overheated since I’ve owned it and really thought it was the original hg that had failed.
Seems like 13b heads are a bit easier to come by and read a few sketchy comments that people on the inter-webs have used them on an 13bt… anyone have some definitive answers?
1110158031 for the 13BT
Vs
1110158020 for the 13B
That does suck, I don’t recall reading about the 13bt head cracking, usually the 3B.
I haven’t fully dug into the main differences between the 13b and 13bt blocks/heads. They both are direct injected, but I’m guessing theyhave different compression ratios due to turbo vs NA. I don’t know the head differences, but it’s possible (I have no idea) the 13B head could raise compression due to it being a non-turbo engine.
You could check with EBI land cruisers in Canada, @70sguy deals with 70 parts out of Canada as well.
Ya I’ve got about 30 calls/texts/emails/dm’s out there so hoping somebody can dredge something up.
A couple shops are looking into new castings, but I’m not sure how I feel about the Chinesium. I think I’d prefer a used OEM, but that definitely could be a can of worms as well..
John @Radd Cruisers has been very helpful and suggests that if it can pass a pressure test and holds pressure when remounted with a composite HG it should be serviceable until a replacement can be found/rebuilt. Not that I was to do 2 head gaskets on a 13bt in a year, but it might keep me rolling.
Some cruiser porn to keep the motivation high!
attempting to dig into the differences on the 13B vs13BT head.
Staring at zoomed in pictures of a 13B head vs the head gasket I have it looks like the passageways are exact.
Valve stem diameter and oil clearance are a few thou different but all the other specs line up.
Curious
Yeah I believe the heads are extremely similar. Oil clearances being looser on turbo engines is a way to help manage heat/friction so I would imagine that’s the reason on an older diesel like this.
Really the only worry I would have is to see if there is any volumetric difference on a 13b head that would raise compression. Only thing I could find is 13bt is 17:1, it appears the 13b is 20:1.
So possibly you could get a thicker head gasket if indeed that is the case to help lower compression, (custom made?) but you would need a 13b head measurements to get that for sure.
Just spitballing.
Just spitballing.
Ok thanks Ben, makes sense.
My thought is looking at the specs for the head/ valves and that both engines spec the same for bore/stroke/displacement and share a common HG that any volumetric difference would come from changes in the piston bowl size/shape.
Would it make sense if the intake valves, stem seals and guide bushings are the same but the exhaust valves are different (same specs) that it’s likely a metallurgical difference to deal with the higher EGT’s of the boosted engine vs non?
Using the downtime productively. EGT pre turbo, coolant temp sensor in the t-stat housing, sensor wires for the battery gauge and oil pressure sensor.
Been raiding the junkyard of various clips off a few early 90’s 4Runners, Tacoma's and Corollas. Not quite factory but clean enough that I don’t notice it.
Looking at some of the vacuum lines and they’re a bit crunchy and a few are absolutely welded in place.
90999-92008 Is 2.6m of bulk vacuum line
(27 cheeseburgers side by side for those following along in imperial)
Called the local Toyota stealership… $167!!!! For 8-1/2ft of vacuum line and it’s gonna take a week. Holy hell.
$37 from Amayama, I think I can wait an extra week. If anyone from the Dinktown dealership is reading this :flipoff2::flipoff2::flipoff2:
Picked up the head on Friday, passed a pressure test and further inspection of the valve seat and injector port shows no cracks anywhere else. I know some people say they can run 3bs with multiple crack depending on the location but I’m still looking for a new head.
There were only 7 bolts when I took off the exhaust manifold, I thought extracting the broken stud was going to be a nightmare but it started spinning after I drilled part-way through it. Came out with an easy out quite politely.
New valve stem seals courtesy of Cruiser Outfitters.
Just waiting on a new head gasket from RADD and this sucker will be going back together.
theres a couple russians on here... maybe reach out?
Finishing touches on the Redarc gauges and a mounting bracket for the low coolant alarm and modules for the guage install. Just have to figure out some settings and then put the dash back together 😅
As the French say “on with his head”…
Thanks John @ RADD Cruisers for the sage advice and parts.
Replacing the chain on the engine hoist with a turnbuckle helped me ever so gently lower the head on.
