Birf Build Blunder?
Azca
If there is a harder way - I will find it...
Surprise AZ.
Okay, not the first time I have done the axle service but, ran into an issue after. I swapped birfs, put in new bearings for each side, and followed specs and OTRAMMs video. Torqued everything and used molly grease in the knuckles and wheel bearings. Set the bearing preload to specs as well (Fish scale pulls at 10 - 12 each side). Also added 100 pads on each side. (Toyota rotors replaced about 2,000 miles ago). Spinning the wheel with the new grease and bearings is more difficult (not binding) than I would think. Due to the molly grease???
Issue. Turning to either side while backing up has a lot of resistance. To the point the vehicle stops itself. What are your thoughts?
Bird cage installed backwards?
The grease is not your problem.
I didn't actually pull the cages, just swapped shafts. That is the only other thing that has me on edge at the moment though. I was certain I got the new c clips to seat properly but, with this issue I am questioning that. That said, when installing the axle flange, I think that would have been apparent.
You used moly grease in the wheel bearings??? That doesnt sound right!
Another subject that has been beaten to death on this forum. It's a non-issue.
I agree with the 100 pads being too thick. Once it gets warm, it is really bad. we have had to grab a used pad from another rig before and swap with a new one so each car had one new 100 pad and one used 100 pad.
I still don't understand the use of 100 Series pads on an 80. Grind the pad material down so it fits? Really?
So you are saying it doesn't make sense to use a part from another vehicle that doesn't fit without modification and offers no real improvement when there is a drop in solution already available? Does not compute.
I would say it’s the pads too. I used them once and they had so much drag I warped a rotor. You likely need to grind them down a good bit or just put on the correct pads for your truck.
I would be it is an issue with
IMO the 100 series pads in an 80 is ih8mud nonsense, buy some upgraded pads like greenstuff ebc if you want better performance, even better delete your abs and lspv.
Not wanting to be the sole defender, and can't say they work better
than the correct pads, although with DBA rotors and 100 series OEM pads (without shims) up front on my 96 FZJ80, it stops much quicker than my 97 FZJ80 with stock rotors and ? unknown pads (likely 80 series). But can't say the 96 stops better due to the larger pads, too many variables.
Either way, haven't had any issues after 50,000 miles until just recently, been getting a faint grinding sound when I first start off from a dead stop that goes away with pedal pressure so have to take a look, assuming the pads are worn out. FWIW.
First, pads were the issue. Took out the shims and issue is corrected.
Brakes. They stink. I have been in search of a way to improve these things without "buying the house". For the last two years. Tried the EBC pads. No significant improvement. Tried power stop rotors (drilled and slotted) again, I can't say that there was any improvement. Replaced the booster, twice, have replaced the master cylinder three times, (twice, OEM and Toyota), tried everyway (two man, pressure, suction), possible to bleed the brakes, multiple times, no change. Took it to toyota to bleed. No improvement. Deleted the LSPV. Helped, a little. Deleted ABS. Easier to bleed and brakes do engage better but, still not impressive. Installed a manual proportioning valve which improved control.
I have used GALLONS of fluid, replaced all soft lines with Mr. T stuff. In the end, after spending what probably could have put a 4x4 labs bumper on the rig, I am still not happy with the brakes. I am ready try hydro at this stage.
I understand the liability issues with modifications to a vehicle. The plain truth of it is just driving a 4x4 today puts you in peril. Changing anything from OEM, places you at additional risk. I am not going to live my life in fear and I don't believe I am placing anyone at any additional risk by driving near them. I hate when they close the national forrests to "protect us". I don't think government should legislate such things as seat belts, junk food, cigarettes (I don't smoke but do eat junk food) because they know what is better for me than I do. Just stay out of my life and I will be happy. Rant over but I absolutely value everyone's opinion and help on this site!
I think this opens up another discussion regarding liability on a street driven vehicle. My LX450 stops just fine with the OEM system.
yes it's been discussed, personal preference I guess, around here lots of modded vehicles, I would rather have brakes that work better, my truck is heavily modified awhile back so that has all gone out the window as far as I am concerned
this is truth: "I am not going to live my life in fear ", living my life in fear of being sued is no fun....
Church:steer::beer::hillbilly::cool:
For you not in the know:flamingo::princess:
