Axle Swap
GA
Any potential issues with swapping the locker axles from a 97 lx450 to a 93 lc? Found a cheap lx450 that would be my donor. I saw threads about going from older to newer but did not see newer to older.
Of course you need the magic dial and other locker stuff, but it's an easy swap.
Buy some moving dollies to help move the axles around on the shop floor. They are WAY too heavy for anyone to lift.
Also, if you have your frame resting on some maxed out 6-ton jack-stands it will keep the body up high enough to allow the axles to droop down enough to make things easy.
Don't tighten the big bolts for the arms/bushings right away. Get them in and get the threads started first. Then get the wheels back on(or move the stands so they are supporting under the axles instead of from the frame. Tighten the big bolts by only turning the side with the washer. Do this with the weight of the vehicle on the suspension.
well i am going to look at this lx450 this weekend so hopefully everything works out and I am able to do something fun this winter besides an engine swap in my father in laws jeep
I'm not sure what you have planned for the old axles, but I need some brackets for my portal swap.
if everything checks out on the lx i will be parting it out after i remove parts i need for my own so my old axles would be up for sale at that point , however i do not know when that will be
The harness is not a direct plug & play between 94 chassis and 97 lexus axles, as I found out when I did my swap. I'd guess your 93 is the same.
Beyond just installing the floor harness, I had to move 3 or 4 pins and IIRC add one splice. Still don't have a backlight for my shifter in the console but with working gear indicator lights in the combination meter I'm fine with this.
I don't remember all of the circuits that had issues, but definitely the ABS impact sensor, rear door speakers, door ajar switches, driver's seatbelt, and maybe some taillight stuff.
Basically if you aren't good with understanding electrical wiring diagrams and troubleshooting with a multimeter, you are in for some fun.
bloc do you have a writeup on your swap because i am sure you are correct on the 93 having some of the same issues as the 94 when pairing up a newer axle
No, no writeup. Was on the to do list but pretty far down said list. If you PM me a reminder I'll try and see if I have any notes at home.. Will be at work for 48hrs and there is no way I'll remember to without help.
Not anyone, I watched my old buddy Jon pick up a fully built and loaded 80 series front locker axles from the ground, carry it across the floor and put it on a bench. He used to say he had "stupid strength" he just didn't know any better. Damn I miss that dude. Cancer sucks. :mad:
^^^dear lord o_O...dude should have been an Olympic powerlifter, I mean it's probably over 400 pounds.
You can cheat and do it the easy way with a dual locker switch from 12voltguy. Way easier than making the factory switch work but it doesn't look as clean.
I just finished rebuilding a dana 70 and dana 60 on my Ram, that fully loaded front end is 600+ lbs. Even with two big blokes, it was still a bear to move. Seeing any one man lift a large 4x4 axle themselves is like seeing a white whale.
Nah I would bet the front axle is 250-280lbs. The rear axle is a little heavier but I bet it's no more than 350.
Eh looks like I was off by 5 pounds lol. This article from Four Wheeler puts a hellfire equipped front axle at 285lbs.
Very surprised. I loaded a stock front e-locked axle with brakes into the back of a pickup by myself and trust me when I say it was a complete pain in the ass. I'd be SHOCKED to find out each end only weighed roughly 140# and I'm no stranger to the picking up and putting down of heavy s***.
I checked and couldn't find my notes.
I will try to remember to pull the driver's kick panel and get a picture of the plug for my now-functioning harness though.. 1994 non-locked chassis, with 1997 LX450 floor, rear, and locker harnesss added and adapted to work. Only thing not functioning at this point is the back-light for the shifter, and IIRC one splice could get that running. I do not have power seats though.. not sure whether my setup would get those working.
I'll also try to get a pin-out and color chart for the wires.. seems it would help someone at some point.
