Any potential issues with swapping the locker axles from a 97 lx450 to a 93 lc? Found a cheap lx450 that would be my donor. I saw threads about going from older to newer but did not see newer to older.
Of course you need the magic dial and other locker stuff, but it's an easy HEAVY swap.
Buy some moving dollies to help move the axles around on the shop floor. They are WAY too heavy for anyone to lift.
Also, if you have your frame resting on some maxed out 6-ton jack-stands it will keep the body up high enough to allow the axles to droop down enough to make things easy.
Don't tighten the big bolts for the arms/bushings right away. Get them in and get the threads started first. Then get the wheels back on(or move the stands so they are supporting under the axles instead of from the frame. Tighten the big bolts by only turning the side with the washer. Do this with the weight of the vehicle on the suspension.
^^^dear lord...dude should have been an Olympic powerlifter, I mean it's probably over 400 pounds.
