Zippy Build thread
GA
I only currently have notes on things I have done to my 93 Land Cruiser, but going forward will add pictures of projects as they are on going.
07/27/13 Purchased my first Land Cruiser to replace the 1981 CJ-8 we had for Family expeditions and off roaring trips.
08/02/13 Obtained 54mm axle socket for upcoming knuckle rebuild.
08/04/13 Removed running boards.
08/07/13 Replaced driver's side taillight Toyota Part Number 81560-60241.
08/08/13 Replaced driver's exterior door handle, in the process cracked interior door handle cover. Toyota Part Number 69220-60020-03.
08/11/13 Replaced twin drive belts and ac belt at 302790 miles, Toyota Part Numbers 99332-10910-83 and 90916-02353-83.
09/24/13 Installed center differential lock switch, Toyota Part Number 84725-60010.
07/30/14 Replaced gas door, broke door kick in process. Toyota Part Number 77037-12050 Lock Sub-Assy-Fuel.
07/04/15-07/05/15 Finished knuckle rebuild, replaced knuckles, calipers, rotors, brake pads, rubber brake hose. Installed new BF Goodrich KO2 275 70R16 tires. Added AVM manual locking hubs at 302870 miles. Toyota Part Numbers 12157-10010, 90310-35010, 43202-60032, 90366-20003, 43435-60020, 43436-60011, 90313-93003, 90311-62001, 90214-42030, 90215-42025, 90520-31007, 43422-60060, 90521-34005, 43211-60120, 43212-60120, 90101-12144, 90201-12452, 47730-60060-84, 47750-60060-84, 43512-60090, 04465-60220, 04947-60090, 90947-02A16, 90430-10074. Slee Part Number SOF1224, SOF1063, SOF1228.
07/10/15-07/12/15 Old Man Emu 2" Medium Load Lift Kit Installed. Nitorcharger shocks, coil springs, caster bushings, steering stabilizer. Installed remaining part for part-time conversion kit. Marks 4wd adapters. New gear oil added to transfer case, Valvoline 75w-90 synthetic. 302790 miles. Speedometer slow to start working. Slee Part Number Sof1224, SOF1063, SOF1228, SOF1051. ARB Part Number ARB1019 OME2851, OME2860, N60018-S, N60020-S, OMECA77B, OMESD24.
08/22/2015 Transmission drained, magnets cleaned. 305142 miles. Valvoline Full Synthetic ATF Maxlife Dex/Merc Marcon LV.
03/05/16 Factory exhaust removed. Pacemaker headers and King Brown exhaust system ready to install. Toyota Part Number 17173-66020, 17198-66010, 90179-10128, 90116-10169.
03/09/16-03/10/16 White Knuckle Off-road Rock Sliders installed, with Top plates.
03/29/16 Fan Shroud, Blue Fan Clutch mod. 10,000 CST silicone used. Toyota Part Number 16711-66031 Aisin FCT-004 Engine cooling fan clutch Team Associated 5455 Factory Team Silicone Differential Fluid. Water Pump and Thermostat replaced Toyota Part Number Aisin WPT-023 Engine Water Pump 90916-03117, 16346-66020.
04/02/16 Radiator and Heater hose replacement. PHH replaced with xtreme Samco silicone hose and Breeze constant torque clamps. Radiator and heater hoses replaced with OEM Toyota parts and Breeze Constant torque clamps. Heater pipe from 95-97 80 series land cruiser used. Throttle cable bracket from 95-97 80 series land cruiser installed. PAIR system deleted. Toyota Part Number 16261-66040, 16267-66020, 16264-66021, 99555-10200, 99556-30100, 87245-60340, 87245-60490, 87245-60350, 87245-60480, 89465-60110, 16571-66030, 16572-66021, 16573-66010. Installed used inner fender reinstalled outer fender.
04/04/16 ARB Bullbar installed. Duiser offroad heavy duty tow points installed.
04/08/16 IPF Dual Beam auxiliary lights installed. Pacemaker Headers PH12650F, PH12650R, PHB080P King Brown Exhaust TL80-256C-KB, TL80-256R-KB Toyota Part Number O2 Sensor 89465-60110.
08/16/16 Tom's Garage extracted two bolts from frame and then installed main bumper portion for Slee Rear Bumper.
08/17/16 Finished installing Rear Bumper swingouts.
Upcoming planned projects: Install Mile Marker Hydraulic Winch, Stainless Brake Lines, Tailgate Storage Kit by Trail Tailor, E-Locker Retrofit from 94 80 to Zippy, Sub-tank Install, Oh crap bar for Passenger Side, and Cloth Seats from a 91 80 to Zippy.
Last summer in Colorado, at some point I deleted the fender flares and spent a few months finding plastic plugs that fit every hole left in the body. Temporary fix for now.
Taking longer than expected because of having to take parts off of the old leather seats but should have "new" cloth seats installed by the end of the week. Will post up when all are installed in truck.
Progress is slow on this install with removing all the hardware and putting it on the cloth seats. The issue that has arisen is that the one completed 2nd row seat doesn't currently latch to the floor.
Not as much fun as trying to install the seats but my head will thank me later. New struts for the rear hatch and hood. Also finished up the other second row seat and it also doesn't latch to hold the seat down so need to figure that one out still….
2nd row seats now fully installed just took some aggressive persuasion to get them to finally latch but now they actually seem to work every time if slammed down into place. Now need to figure out the seat belt issue on the front seats. Does anyone have pictures of a 91 or 92 seat belt and how it attaches to the floor? Does it have a captive nut that a 93 and older does not have or is there a bracket that I need to source. Stupidly did not think of this when I obtained the seats.
Seats don't match interior color but until such time as I can either get them all reupholstered it will work. For the time being will mostly hide the tan houndstooth behind these gray towel seat covers with Toyota badging. This completes manual cloth seat switch for the time being.
Pulled the ps pump off of the 94 to get the gear off to install on new ps pump for Zippy… Harbor freight being the only place here that I could find a 17 mm 12 point impact socket to remove nut holding gear.
@half k cruiser I am working towards the winch install with the work on the power steering, just to make sure my idea for hose routing and getting new hydraulic hose made isn't completely crazy here is my plan and how does it compare to yours. Starting at the banjo portion of the hydraulic hose get a new hose made using that port to length on port of winch, then from winch have the other high pressure hose run re using the elbow into the steering gear box, then run the low pressure hose to the cooler that I got from @2fpower then from the cooler to the reservoir and from the reservoir back to the pump.
Dropped off hoses and connectors today at local hydraulic shop today to make some custom pieces for the winch install, hopefully I measured correctly. Should be ready tomorrow for pickup.
Ok I picked up the hydraulic hoses that I had made today so hope to install new ps pump and mile marker winch into Zippy tomorrow will post pictures of that little project as it goes.
