Attempting the next best engine swap for 80s IMO
Hmm that actually makes a lot of sense. I've been in a '21 gas suburban and it has buttons, not mechanical linkage for the transmission. I can't imagine they would have an entirely different shifter setup for the diesel version.
Thanks for all the info you've posted on your build. Very interesting.
I can get you one for a good deal if you are interested. Probably can put a whole package together for you to help put all the little things in. Hell I’ll even install one for you. Just let me know
Newest update I have removed the electric thermo management crap and now running my adapter I designed. I should now be able to run the engine a lot cooler than it normally runs. It usually runs around 240 degrees which is crazy to me but they claim it helps with fuel economy. Using a 190 thermostat so 210 should be easy to maintain View attachment 4031022
Also with that electric crap my heat wouldn’t get hot until fully warmed up which takes forever if I’m just going around town.
Now my heater core is ran a lot simpler
Hey! its me from youtube! the one asking if you had a write up, i know lm2 and lzo have alot of issues with these if you can find a solution to bypass this im pretty sure the silverado/sierra guys would love this to
First prototype of V 2.0 of the adapter has finally landed and we are going to test the first article on the new Duramax 3.0 10 speed conversion. This adapter version eliminates the need for the 95-97 trans adapter piece. After testing we will pull the trigger on changes/updates and get these ordered up.
cant wait! im looking forward to this swap on my 94
I’ve been running my adapter for a while now and even made a website to start selling parts as I develop them. I’ve been running a 3d printed adapter with no issues but have since started making them out of aluminum and they look fantastic
My website is DrewTheCarGuy.com
My website sucks but I’ll slowly make it look better
I’ve been running my adapter for a while now and even made a website to start selling parts as I develop them. I’ve been running a 3d printed adapter with no issues but have since started making them out of aluminum and they look fantastic View attachment 4049916View attachment 4049917View attachment 4049918
Looks nice.
How's that lower temp thermostat working out so far? Most of what I've read about diesels, especially newer diesels, says they run well with more heat than a gas motor. It makes sense: diesel is a less volatile fuel, and needs more heat for clean and efficient combustion. It's not night and day, but it seems like the ideal block temp is warmer than would be ideal for gas.
My fear is that you'll end up fighting carbon deposits with that 190 stat... just speculation, but it's worth a thought.
If you get those thermostat adapters anodized they will look good indefinitely. If not they will be pretty corroded in a couple years.
That’s a good point, I was just trying to keep the costs down as much as I could since I’m not here trying to make a living, just trying to help people do the swap
25mpg-ish with 37s and stock R&P (I presume) 😲. Badass.
I told him he should re-gear with 3.55s.
I didn't know this ratio is an option for the 80 series since most of us go the other way 😁
I'm not an engineer, but I would think that dropping the RPM by roughly 13% should improve fuel economy. I know it seems to work the other way around when people go up to 4.88s for 37s with a 1FZ, but Drew's LM2 has way more torque and horsepower. I wonder if @torfab has an opinion?
3.55 ring and pinion sets from Oz
And a lower first gear ;)
I run stock 4.10 gears with 37's in my L87 10 speed powered 80 and that's about the same output as the L87 Silverado with its stock gears and tires. I would maybe do an overdrive conversion on the t-case instead of re-gearing though. I'm in the process of putting this same combo into my 40th anniversary 80 series so I will have more real world opinions after I'm done.
