I want to add a push button start button in parallel to my keyed start. I was thinking of using the "antenna down" button because it is hot with the key in the ON position, and I'm a little lazy and don't want to add a new button.
I have a couple of questions that my searches have not answered.
1. Can I directly wire 12 volts to the starter (low voltage line) or do i need a fuse and/or relay?
2. If this is feasible should I splice the "antenna down" wire and run it all the way to the starter or should I splice it into the wire running to the starter at the back of the ignition?
3. is the "antenna down" wire sufficient gauge for this purpose?
I cannot seem to find this info via search. Thanks a lot for your thoughts.
