So are those 33's with factory spring?
Would you mind getting a few closer shots showing how the tires fill the wheel openings?
Thanks!
DieselFJ, SWEET LOOKING PIG.
Thanks Bob.
The 79 is in a bad state, I tore it down years ago, it was a factory A/C, Factory PS rig with all emissions etc... attached. It needed sheet metal work like all 55's, but I don't mind sheet metal work. I was intending to use it for camping/off roading, definitely not rock crawling, but now I'd like to just get it back on the road eventually. I welded on some 2x4 sliders for the rockers, and cut the front fenders, but now I wish I'd just left it stock with a mild lift. Now I'm not sure what to do with it. I put some cable locked 70 series axles on it, but I'm going to swap those over to my 40 so it'll be sitting pretty stock minus the 70 series OME lift.Good to have you back. Any updates on the 79? What's the plans for both of them, camping rigs, long distance travel, rock wagons?
Oh, and that doesn't include the 80 I'd like to swap 1HZ-T into and an HJ47 that I'd like to try a new turbo setup. What is wrong with me.......
I was going to say Kurt has a sweet setup for 55s, but you have to move the rear perches. Not too big of a deal.Any other options that don’t require moving the rear spring perches?
I did it in my ‘79, but I’d like to keep these in the factory location. I want to feel the difference in the ride if there is any.I was going to say Kurt has a sweet setup for 55s, but you have to move the rear perches. Not too big of a deal.
Good to see you came back to the sty! You sure you want to though? Back to back posts with the beating your head against the wall emoji...
What are you thinking about doing with the rig? That is a good place to start a suspension discussion. Lots of options!
@scrapdaddy has a fix for them, hopefully he'll be along shortly with some help.it looks to be just wore.
So, after just over 9 years after I sold this I actually bought it back again. I knew the guy who bought it and had actually done work on it while he owned it, but he decided it was time to let it go and gave me first dibs. I definitely didn't need it as I have a 79 still, but it runs and I figure it couldn't hurt to have another one. At some point in time I need to quit buying and just finish the Cruisers I have.![]()
