Andy's (possible) pig build-up
Houston, TX
Website
www.flickr.com
Hi FJ55 people!
Last week, I bought 1TonToy's FJ55. What a great looking rig! Australian right-hand-drive, little rust, nice Dual-Fuel Propane setup, big ol' 10-leaf springs, 2F, aftermarket header (the good kind supposedly), Front buckets, H42, 10 gallon tanks, aftermarket and CB radio, 2 1/2 in. lift, dual battery hookup. I don't have any plans as of yet, but zuluzeugma wanted to SOA it. Valves need to be adjusted, knuckles need rebuild, and t-case need a thorough inspection. I'm thinking stock wheels and bench seat?
Yeaaaaaaah Baby!!!!!!!! That's a nice rig firstade. What a sweet looking interior. Stock wheels w/ caps and a lift will certainly set off a truck that is otherwise just plain nice. Congrats on your purchase and here's my welcome to you:flipoff2:. Dave
Looking forward to hearing more about your progress (although you're in the 23rd century while I'm circa 1495 on my progress!!!)
Nice looking 55. Congrats.
I've got a decent 55 bench seat if you end up going that route. It's located in Colorado. PM if you are interested.
Maybe I'm missing something. You want to SOA that? Blasphamey. (Chuck will disagree:D) It looks to good to trash on the trail. There are very few barn door setups in the US. I cannot imagine very good performace out of a dual fuel setup with big tires.
I'd say keep the lift you have. Get some more aggresive tires. Maybe some taller pizza cutter BFGs KO's on stock rims and be done with it. Go SOa and expect to spend a lot of money. Gonna have to go power steering then.
Stick with the buckets. Just a lot more comfortable ride and much better on the tail. You will be sliding all around. Spend you time fixing the rust. There is probably more there than you can see. Refine all the little things and improve the ride. Maybe some Bilstiens, new body bushings, sway bar bushings, a bumper and a winch. A PTO would be the bomb.
Looks good the way it is though. I like the doo doo brown.
yes, 35s will be cutting it close for sua, unless you go real skinny. also, keep in mind that there's not much to cut out on the rear fenderwell, so consider that when looking at the diameter of the tire
thanks for the feedback guys. I know I want to grab a pair of OEM's, and maybe 33's? I said I would initially wheel it, but I have second thoughts. It's in good shape. It doesn't have the ambi doors though.
It wasn't as strange as I thought. It took about 5 minutes to get good enough to be 'roadworthy'. I get alot of strange looks, but I just smile at them.
Hi FJ55 people!
Are those factory 3 point belts in the front?
WOW, that is a nice rig. is it hard to drive on the wrong side and shift with your left hand? I heard it is like someone else is doing it. is that true?
what are you talking about, "the wrong side" that my friend is the RIGHT side! you guys drive on the WRONG side :grinpimp:
I kinda' made a parts list of things that need immediate fixin' and things that could possibly, hopefully be done. Did a semi thorough walk through today. It isn't anything extreme, but I am new to Landcruisers. Hopefully it will be some of dat' good learnin':
Fix:
1. Blown Manifold Gasket
2. Clacking lifter
3. Door dent
4. Cracked driver mirror
5. Driver door hinge
6. Driver window regulator
7. Weepie Warn Hubs
8. Leaky Transfer Case
9. New drum shoes all around
Dream:
1. Gas Shocks: Trollhole recommended Bilistien (buddy recommended BDS monotubes, but he is a Heep guy)
2. Carb cleanup or rebuild
3. New suspension bushings
4. New body bushings
5. 33' BFG's on OEM's
6. New rag joint
7. Alignment
8. Tie rods
9. Roof Rack
10. Short shackled front bumper
11. disc brakes
12. Zulu's rear end:eek:
They look original to me.
Could I see a picture of where/how it mounts? The only 3 point Piggy belts I have seen mount in the roof over the rear doors. If there is emough meat in the B pillar I will consider mounting there...
Fix:
2. Clacking lifter
3. Door dent
7. Weepie Warn Hubs
Dream:
6. New rag joint
7. Alignment
8. Tie rods
9. Roof Rack
11. disc brakes
Address driveability - disc brakes, TRE's, bushings, alignment and rag joint. If any of those need addressing - move them up in priority.
Mark A or Jim C can help you with carb. Not sure how much experience they have with propane though...
