Build AK HJ-75
Cut out complete.
Have to figure out what to do with these 90 degree bends. The outer pieces have a 90 degree bends to mate up with the inner panel which also has a 90 degree bends. The outside rails were attached to these 90 degree bends.
You are a brave man. I would have needed to take some liquid encouragement before making those cuts!!!
Hello,
x2.
This is not for the faint of heart.
On the other hand, this setup reminds me of Andrew White's pop-top Troopie.
Juan
I think I have the bolt it down done. It is not bolted down yet for final attachment, will wait till I have the fold up/down bed done. Because of how thin the aluminum of the rtt is I was worried that if I use some weather stripping between the bottom of the rtt and top of the cap that spaces between the hold down bolts would potentially bulge up. So I installed 1x3 aluminum angle on top of the rtt sheet metal. I placed the 1” up on the outside so that it would then also provide a lip to hold small stuff, like phones, flashlights, snacks, and what not. So next to build the bed.
This is really cool.
It's infecting my brain with thoughts of cutting a big hole in the roof of the Troopy and putting a pop top on it :)
One thing that has been bothering me for a while is that the sides would bend down a little bit when I would put my total weight on the floor. So, then add a wife to the weight and I really didn’t like how much more the sides would bend down. When I built the cap and used 2x2 steel for the upper for/aft run I didn’t think about the reduced twisting strength. So I built a brace, no flexing now.
