Build AK HJ-75
Care package from down under. Who has attached a engine watchdog on their 12HT?
I didn’t pay close enough attention to make sure that the bottom half of the front piece was flat. When I went to put the assembly on the back of the truck the bottom half of the front piece was bowed out some, enough to scratch/touch the back of the cab on install. I had planned on using 4 rivnuts across the bottom part with some foam gasket to hold the bottom part solid. So the rivnuts helped to suck in the bowed out part, to hold it flat to the bed.
I like using notched rivnuts since this helps reduce chances of Spinning.
One of those two steps forward one step back moments. I didn’t like how think the weather stripping was that I used around the outside of the outside frame. So removed it and installed a different style that squishes better.
I used the one on the left first, then switched to the one on the right.
