94 Turbo?
Virginia Beach
Alright, I was hesitant to post this because I could have swore that this has been discussed. I searched through the 80 series for the answer but no luck.
Can you turbo charge a 94 landcruiser? I have seen the kits for years 95-97, but none for 94. Is this because of the extra emissions junk on the passenger side of the engine?
I'm sure a turbo can be installed on the 94. There are no turbo "kits" for the 80 series (in the US), so whatever you do, it would be completely custom. Slee's website says they are planning a Turbo for the FZJ80, but not sure how that is going.
Do a remote turbo like the STS.
Your talking about down the exhaust? I have seen those, but didn't like that set up, especially being under the car and worrying about four wheeling with it under there. You pointed out that emmissions thing to me, what is it called again?
It could be tucked up where the stock spare mounts. I just watched some car show that they installed one of these. Quite impressive.
I believe it's the PAIR valve.
Yes it definately can and has been done.
Trust me I know.
Landtank is correct in his statement that you must compensate for the lean characteristics of the 93-94 but after that it is game on so to speak and in a very good way.
Don't mean to hijack the thread here but Landcrusher assuming you're a pretty big Chargers fan what happened to Charlie Whitehurst at backup quarterback? And yes you can turbo anything with enough $$$$.
If you are serious about this the first thing you need to do is work out the fueling issue. The rest is pretty straight forward and just a matter of getting it on the truck.
On smaller engines with the vane style AFM you would simply install a similar AFM from a larger engine and then compensate for the lower base injector calculation with a larger injector. Unfortunately you have the largest Vane style AFM already.
It might be possible to do something similar by engineering a calibrated bypass pipe so the AFM only sees a portion of the actual air flow. This way you could run larger injectors and the AFM would then continue to function up into the boost range instead of cutting off when boost starts to build. All theoretical but it is based on others experience with smaller Toyota engines of this era.
I personally would try and work with the stock ECM and avoid piggy backs. Mainly because this is my comfort zone but also because of the build in safety that comes with them.
I remeber at some point saw the SC kit include a extra injector .. this can't be aplyed to the Turbo idea and run extra injector ( one or more ) for the boost situation when the ECU read WOT ?
Or maybe I'm speaking stupid things .. :frown:
I thought the extra injector was for other TRD SC applications, ie. 3.4l V6?
It looks like fuel management computer and injectors are the biggest issues. I assume fuel pump, filter along with o2 sensor will need to be gone through. Basically would be buying everything piece by piece until I had it all then install. What would be the suggestion for a turbo? I've seen garrett, hks and even seen a thread about using an old volvo turbo.
I did all the math on the Garrett site and came away with the GT35R with a T4 .82 housing. It will hopefully be on this summer.
It all depends on how much boost and how much soon you want it at the rpm range ... the .82 AR looks ( IMOP ) for huge boost ideas, little late in the power band .. but it all depends on your dribving style and what you are specting for your engine ..
The turbine side at .68 looks nice to me to get full boost at 2k - 2500 rpm you can handle it throught the band up to 3500 - 4000rpm and then wastegated ..
It all depends on trim also .. long theme. Keep us posted .. I love turboed engines.
At 10.0 psi it was dead center on the compressor map and the .82 is almost identical to that which Safari used and this is a BB unit so it should come in even sooner. But only time will tell for sure.
Count me in your thread when you start your build .. I thought Aussies are using TG28 . ?
BB it's definately a gread feature ..
