Well I got my rear brakes on and replaced a bunch of hard lines. The soft lines will have to get replaced as well but I didn't get that far. Front brakes drag hard so I'll have to look into them in the future along with rear wheel bearings.
Next was oil pan had a bunch of sludge in the bottom and low oil pressure.
Drained, cleaned pan, checked pump, new gasket, reinstalled, new filter, vr1 oil. Helped a bit but I think I'll be replacing the pump. Can't get a 1f pump from my short research but I have plenty of 2f pumps and pans so hopefully I can just swap.
Now that I can drive it around the block I learned it needs a clutch... I don't have a trans jack for my lift and as a might as well I pulled the trans cover.
Cleaned it up
Barely..
anyway I have a new Asian clutch on the way but I also have a Toyota car show on oct 17th I wanna take this and the yellow one to so now it's just fix anyway possible to be able to drive there.
Wonderful cage to lift from
I'll be putting in a used clutch disc unless my new one shows up very soon. Don't worry I'll pull it back out and put the new one in... someday.
Thoughts on sound deadening? I did it to my Miata and I liked it but I cared very little about that car when I did it and I care more about the longevity of this. Any other suggestions past the sticky foil sheets to lay down?
