40-Series Paint Type (Polyurethane)
North Georgia
Website
marcstpierrephotography.com
Hello :
I've been long wanting to paint my FJ40 a specific, non-Toyota color. One that many here have already universally supported me on. A really cool-looking military-type color of an authentic Olive Drab, that had been used during the early 70's until the mid 80's on Cobra attack helicopters.
The coating / paint was produced by DuPont and is from their high-end, Imron line. It is a 2K polyurethane, that is fully UV stable, and does not chalk. It's an industrial grade, commercial-type fleet coating, used currently often on tractor-trailer trucks. Many here not only widely supported the (non-Toyota) color I speak, several had also highly praised the (expensive) Imron line of paint, itself.
The QUESTION I have is : if the somewhat thick, polyurethane of the Imron would be seemingly okay (a good idea) on the outside (and inside) body of the vehicle (as lots of thumbs-up were once given) -- why then is the similarly chemically fabricated polyurethane of Monstaliner (or Raptor) such a *taboo* for the outside body of the 40-Series (I speak of applied not only as a tinted color, but applied as *overtly smooth* - which technically can be done) ... ??
What I do understand is polyurethane is somewhat like that of a plastic (without knowing for sure, I think it probably IS a plastic) and bonds heavily to itself, regardless of the condition of the metal underneath. And hence would not overtly reveal such future condition of metal.
And what I also understand is that *if* the up-front *clean & rustless* metal is *well prepared* (ample sealer, thorough 2K epoxy primer, etc) - the ceramic-induced polyurethane of Monstaliner (or Raptor) would naturally serve as a *shield* - effectively preventing induced moisture upon the metal (of course provided imperfections don't develop within the paint - allowing moisture to the metal at those specific points - but really, ANY coating could fail at various points like that).
Just asking, as I'd like your input on this.
~Marc
Just because it’s a polyurethane doesn’t mean it’s just like other polyurethanes. After all, you wouldn’t clearcoat your car with Minwax polyurethane. There are many different types of polys out there.
Imron is not a thick paint. It’s not intended to be applied more than a few mils thick. Nowhere near that of a bedliner material.
Yes, polys have high cohesive strength, but when applied to a properly applied epoxy, they also have excellent adhesive strength. Cohesive strength isn’t a bad trait unless the adhesion was compromised because of poor prep or excessive film thickness (or any other failure to apply/mix properly).
All paints reduce the amount of moisture that can reach the substrate they’re applied to, but none of them block 100% of oxygen and water. Paints by themselves would rarely block enough O2 and H20 on their own and that’s one of the reasons primers are used.
Short answer: because paint can be fairly easily sanded off, and Monstaliner cannot. Also, many applications of bed liner to the outside of trucks are done by people too cheap to do bodywork and prep correctly, so they come across as a hillbilly solution. Anything that causes a collective groan of 90% of people is probably not a good idea. So, this dichotomy you speak of had less to do with paint chemistry and water permeation than with psychology.
I concur. ... I'm not yet knowing the specific chemistries of such different type polyurethanes, but would like to learn more about this. ... But LOL, I do have a can of Minwax clear coat polyurethane (that I'm using atop a stained a wood post) - and would NEVER DREAM of dumping the stuff on a car... :)
I'm seeing that the Dry Film Thickness of the polyurethane DuPont Imron Elite (that I'm seeking to utilize) is to be something like 1.8 to 2.2 mils. Conversely, the DFT of the suggested two coats of Monstaliner polyurethane is to be around 40 mils (which from that, I now see the striking difference of the two). And I had always considered Raptor Liner to be just like Monstaliner (or basically similar to an extent - with its integrated ceramic dust particulate), and I'm now seeing that two to three coats of Raptor to have a DFT of around 230 mils. And as a self-reference to a historically typical bedliner material, I'm noticing Herculiner to be upwards of that, at 1/16th inch thick (however that relates). - - So now, after learning of the resulting thickness, alone, between the 2.2 mils of the Imron Elite & that of the much thicker bedliner polyurethanes - I can see where there is potentially a resulting difference of chemistry.
Agreed.
I'd think the thick nature of the Monstaliner & Raptor "paints," with their induced ceramic particulate, would pretty much prevent ANY water or O2 from being absorbed solidly through (within the "healthy" areas of the coating). And I'd think that an epoxy primer would ideally be pre-applied under this. I read somewhere on the Monstaliner website, their product would 100% encapsulate the substrate. But regardless, I'd be one to apply the 2 or 3 mils of 2K epoxy primer - as you mentioned.
Thanks for your input !!
LOL... I'd say that's a quotable quote :-) ... and true about MANY things in life. ... I'll go back to where I was - with my head submerged into the sand. :-)
I am planned to paint my BJ42 with a polyurethane paint. Because it’s easy to paint, durable, not chalk and the gloss is good.
This is painted with an acrylic polyurethane paint:
Nice 45! If yours, more pic please.
The QUESTION I have is : Anything that causes a collective groan of 90% of people is probably not a good idea. So, this dichotomy you speak of had less to do with paint chemistry and water permeation than with psychology.
I think 91% of us would agree with any sentence having at least two big words....
dichotomy?...that's cutting off your thingy..right?
The two sides of polyurethane (paint vs. monstaliner) is the dichotomy of which I speak. I was not referring to John Bobbitt and his unfortunate separation.
dichotomy
[dahy-kot-uh-mee]
division into two parts, kinds, etc.; subdivision into halves or pairs.
dichotomy
[dahy-kot-uh-mee]
I don't know if it was so unfortunate for him. It seems, financially, he did better after the separation. Like Octomom, there was a short
term financial windfall. I always wondered what went through the mind of the person who found his little friend just laying in the road.
I mean it's not like finding a quarter that someone dropped. Do you cast it into clear polyurethane like a scorpion to make a cool paperweight.
There's so many uses for polurethane.... couldn't find the other image:)
