Got my front seats rebuild over the weekend. Took both seats down to the metal frames, sandblasted all parts, POR15 the metal and started reassembling it the next day. The high strength 3M-90 spray adhesive is some great stuff to restore the foam.
Used some tricks I had learned from the upholstery I had done on my wife's 69 beetle. I had purchased a seat bottom from SOR and decided I was not going to use that as I did not like the quality of that foam. So I ended up reusing all my old foam and covered that with a layer of thcik felt to give it more volume and strength.
I think they turned out quite nice. If anyone needs some detailed shots as to how the headrest guides are attached inside the backrest, I can post some of those.View attachment 939521 View attachment 939522
Yep just the body unless the rest is really cheap.
Saw that one i wish it was closer
Lenny are you thinking of putting a Cruiser body on your Zuk?
Carencro is just north of Lafayette 3hrs and some change from here. I maybe in Laffy this weekend and can check it out for ya.
NopeLenny are you thinking of putting a Cruiser body on your Zuk?
Only if it is on your way.
No 12HT...is alot bigger and better. I had a 1KZ-TE.
One more question about the FJ40 windshields. Are they not tempered and double glass with plastic sandwiched in between?
So how can you cut one of these in a day and have it installed the same day? Anyone could clarify that for me?
Thanks
