So you are saying it's not tempered. I am a bit amazed. Is that the way the original windshields were made?
Well, first I removed the steel bottom plate from it, cleaned up all the rust that was stuck to the foam.I would like to see how you refreshed the stock foam. I'm hoping to give the interior some attention later on in winter or spring.
What are the short and long term issues with a leaking front inner axle seal? My new "HD" Marlin seal failed badly with just a few miles.
I have read that the gear oil will breakdown the knuckle grease and cause premature bearing failure.
My passenger side had a very slight leak for around 5 years and I ended up having to replace all the bearings and races because some fell apart when installing the ARB and RCV axles a couple of months ago.
Damnit I don't want to do that job again and I am enjoying my weekend cruiser drives!
Usually if an inner axle seals fails shortly after installation, then it was damaged during install. I've seen this happen time and again.
You have to be very careful when installing the inner axle shaft and birf combo. Make sure you don't let the weight if the pair rest on the seal and then just slide it in.
To avoid this type of damage, I grab the birf ball with my left hand. Then I grab the splines at the hub end of the birf with my right hand. That allows the most "control" as far as installation goes.
I've installed and sold literally hundreds of the marlin seals and have had virtually no problems.
The oem inner seals are a lot more sensitive to this type of damage due to the very thin rubber liner.
You've just been Georgled.
Mt god that was a provocative post. I need a cigarette.
Georg talking about inserting something and you get all excited. Those firemen and their hoses.
JT.... I think we are going to need your guidance here.
