For Sale Ultra Rare 1982 FJ40 Diesel Conversion - 12H-T, H55F. Tacoma, WA
Pacific NW
***SOLD*** Thanks for all the interest, hopefully I can get her back someday!
This is my dream rig. It's a 1982 FJ40, professionally converted to the much coveted 12H-T diesel engine and mated to a H55F 5sp transmission. This truck only has 5000 miles on it since it's build of pure awesomeness. I swore I would never part with it, but the impending arrival of our first child isn't leaving me with much choice at this point. Some slight surface rust in places, no cancer at all. The drivers seat has a 3-4 inch tear in it. Those are all slight cosmetic issues, though.. the mechanicals are pristine and drool-worthy. Big amazing diesel, fully resealed (low miles on the engine prior to the rework ,and those of you in the know definitely know how these engines can run for 300-400K miles before needing a rebuild). Dual fuel tank system. Dual electrical systems. Warn locking hubs.
*This Rig is titled as a diesel!*
I had the rig professionally appraised by Automotive Appraisal Services, the same firm that deals with Icon down in SoCal. The rig appraised at ~$45,000, which is clearly much more than I am listing it at. Please feel free to email me if you have any questions, want to come by and see it, or would like to see more photos.
Rock on.
Tim
ticurlett AT gmail DOT com
A long, but not comprehensive, list of work that's been done:
·12HT turbo diesel engine installed last year
·Twin diesel tanks mean that the truck has a range of 800 to 1,000 miles without refueling.
·H55F 5-speed transmission was installed, originally from Toyota dealer bought brand new.
·New clutch and rear main seal, machined flywheel, etc
·Engine was torn down to long block and re-sealed, new belts, water pump, paint, etc with all OEM parts
·Rebuilt turbo
·Ceramic coated turbo exhaust housing and exhaust manifold
·Cleaned and painted block and accessories
·Added 2nd alternator for extra electrical system
·Rebuilt and re-wound 24 volt alternator for 12 volts
·re-worked starter for 12 volts instead of 24 (Using factory Toyota parts)
·Custom power steering lines made with hard and soft lines
·Transfer case was rebuilt with new bearings and gaskets (FJ62 split case was used)
·custom crossmember brackets created, and used factory brace for transmission mount
·FJ60 power steering box was mounted on reinforced frame for better steering
·new tie rod ends installed and custom drag link for FJ60 steering box
·Custom dual battery tray installed for starting/running batteries
·Custom battery tray for secondary battery
·Electrical harness installed for accessories, truly separate from main harness with it's own alternator and batter
·Secondary switching panel to control accessories on system
·H4 headlight upgrade
·Front knuckle rebuild with new bearings, seals, brake calipers and pads
·Replaced rear diff with a lower mile unit
·Custom gauge bezel CNC machined to fit Moal Bomber gauges
·10 custom gauges installed to tell speed, RPM, temp, oil, volt 1, volt 2, fuel 1, fuel 2, boost, pyro
·Secondary fuel tank to double fuel capacity with switching valve to select tank
·Stereo with cd, mp3, connected with waterproof speakers in rear
·Lockbox mounted in cab for secure storage
·CB radio mounted under dash
·Inverter mounted in rear cabin
·rearview camera mounted on upper windshield frame
·OME Old Man Emu heavy lift kit with caster correction, shocks, steering stabilizer, new u-bolts, greasable shackles
·ARB Bull bar with winch mount
·4+Plus rear swing away bumper with tire and fuel can carrier
·5' hi-lift mounted on rear bumper
·additional backup lamp mounted on bumper
·KC lights and LED lights on front bumper
·Ford F250 shock towers
·Tires purchased mid 2013, and have less than 5,000 miles
·new front and rear custom drivelines by "Drivelines NW"
·Custom exhaust tucked up above the frame rail.
Album: 1982 FJ40 DIESEL!
by timmyc99
Ask and you shall receive!
Speedo, Tachy, 2x Battery, 2x Fuel, Boost, Pyro!
Yepper, 5-Speed Manual. She hasn't had any trouble sitting at 65mph on the highway... 5th is very wide, I bet she has a lot of headroom; I just haven't pushed her. I would say a very rough estimate would be in the mid 20mile/gal. With the dual fuel tanks she'll pretty much go forever.
sell that 40 and you will never be the same again!
Hello
Very Interested in your truck.Just sold my LHD 81 series and Iam looking at getting back to the basics.
Send me a message with your email or phone.Would like to talk.Iam located in the North Okanagan,just across
the border from you.
by timmyc99[/QUOTE]
Hello.Very interested in truck.
This is my dream rig. It's a 1982 FJ40, professionally converted to the much coveted 12H-T diesel engine and mated to a H55F 5sp transmission. This truck only has 5000 miles on it since it's full rebuild of pure awesomeness. I swore I would never part with it, but the impending arrival of our first child isn't leaving me with much choice at this point. Some slight surface rust in places, no cancer at all. The drivers seat has a 3-4 inch tear in it. Those are all slight cosmetic issues, though.. the mechanicals are pristine and drool-worthy. Big amazing diesel, fully rebuilt (low miles on the engine prior to the rebuild,and those of you in the know definitely know how these engines can run for 300-400K miles before needing another rebuild). Dual fuel tank system. Dual electrical systems. Warn locking hubs.
I had the rig professionally appraised by Automotive Appraisal Services, the same firm that deals with Icon down in SoCal. The rig appraised at ~$45,000, which is clearly much more than I am listing it at. Please feel free to email me if you have any questions, want to come by and see it, or would like to see more photos. You may have seen this rig around here about six months ago; I'm just looking to get what I paid for it, asking 25,000.
Rock on.
Tim
·Rebuilt turbo
by timmyc99
