- Thread starter
- #3,281
40 has started running even worse. I was having idle issues. I adjusted the idle mixture from 2.5 turns out to 3.5 out (increasing fuel ratio). I basically kept backing out the screw until the idle stopped increasing and then adjusted it back in a half turn. Since making that adjustment, I didn't have situations where the engine died at idle until 2 days ago, but I think I just masked the underlying problem. I started experiencing a low idle again and I found turning the idle mixture screw another half turn out cleaned up the idle (again, I think I'm just masking the issue as I'm now 4 turns out)
After driving it the other day I can not sit with the clutch in or out with out having my foot on the skinny pedal or the choke out just a hair to keep fuel to it.
So at this point, I'm wondering if I'm having an intermittent vacuum issue. I also wondered if I had a fuel flow/pressure issue, though the fuel stays fixed at the carb site line and I have no issues at driving speeds.
I'm guessing the idle solenoid is toast.......thoughts?
