4:1 gears in a 34mm split case
Negative. Gears came from advance adapters and rebuild kit came from Georg. I’ve been hesitant to call for that reason.
Buzz AA, they can certainly look what model you have, what they sold you and verify everything jives. They are great folks.
Idler gear requires some clearance modifications as well. Haven’t seen anyone talking about that.
Made some decent progress on my lunch break today. Cluster gear is all together with new bearings. All that’s left is Finishing the case.
I am VERY close to being done with the case and I haven’t broke through...yet. There’s still time. Once I think I’m done, I do a full assembly with the transmission output torqued and the transfercase output torqued the disassemble again and check for any contact/witness marks. May be reinstalling this weekend! Thinking about building a adapter to lift it in with my floor jack.
Finished up work early and spent another hour on the case half. I am done with clearencing and did not break through the case!
Waiting on my idler bearings spacer. And I’ll be ready for final assembly!
going to see what I can digup to try and measure the rear case half where I clearanced it. Not sure I have anything that will work.
you can spray the inside with paint to help mark the spots were you might have clearance issues. Assemble and rotate a few rotations.
Shouldn’t be a problem to clean it out after.
May want to modify the breather too while it's on the bench for water crossings.
On your last picture of the split case open. Can you give me a quick explanation of where you had to clearance the case? I see two spots on the left? Is that it?
Bhsdriller highlighted them all.
The two on the left are for the Idler gear, which I haven’t seen anyone talking about. I didn’t do as nearly a nice job on those as I did for low range gear.
