Can't say because I haven't measured the diameter of the pipe. I'll try to get back with you on this later today.
they're about 1 5/8"-1 11/16"
cheers and good work!Gotta admit that drain plug is perfect for the job. When I installed my 2FE I used an expansion plug in the hole.
, until I began driving it to the exhaust shop. The novelty wore off in about 10 seconds. What noise. I thought I was going to go deaf in the 15 mile drive. The noise level difference between being on the throttle and coasting was dramatic. oh yeah...it is a sound all its own, innit?
pics of your pipes?
I'm in the process of a full rebuild on a 2F and like the idea of moving over to the 3FE exhaust manifolds from a flow standpoint. Will they bolt up to all versions of the 2F head castings?
The answer is probably yes but I've only put a 3FE on one 2F head.
All the ports are the same intake and exhaust except that the intake ports have notches in them for the injectors, so you cant use the 3fe intake on a 2f head.The exhaust manifolds line up with the ports on the head? I thought the problem was that while the bolt pattern was the same the port alignment was not.....or is that only on the intake?
