the venturi and reference point makes me think of the differential pressure indication transmitters (DPIT'S) they install for calculating flow rate on some process piping in the patch. Depending on what they are being used on, they will also install a pressure transmitter and sometimes a temperature transmitter to get an exact quantity.
Anyway, I re-read your stuff, my thought is that the original design of this was to proportion fuel based on flow, nut it was for a NA engine, by design it doesn't incorporate air density. Not that it provides a solution to modifying the pump, but I suspect pumps built around turbo'd diesels would provide some idea's on how to run your air lines.
On my 91 cummins there is a line from the intake manifold to the top of the diaphragm cavity and the lower side which contains the spring is just vented to atmosphere, instead of observing flow like on the 3B it looks at boost pressure, in order to govern fuel. Perhaps the 3B diaphragm should run boost pressure to the top and atmosphere on the other (spring side), and then go to a different spring, perhaps even two springs, one smaller sized one inside to create a progressive rate and avoid run away.
Just my perspective.
