- Joined
- Apr 8, 2010
- Threads
- 5
- Messages
- 100
"Was just wondering if we can use a manual boost controller on the reference line?"
-You could, but it would be very "jerky" in operation. The reference pressure would be blocked, resulting in boost throttling of the diaphragm until it opened. Once open, it would operate similar to stock, but I dont think it would work that well, or as well as a needle restrictor valve. With the the needle valve, you get a set flow for any given boost level, as opposed to the on-off function of a boost controller. But feel free to test it out. All good tech test info is welcome here,
"Also what would be the effect of moving the atmosphere reference line before turbo?"
This would give a similar effect to the boost throttling described earlier. Would be much the same as just disconnecting it and having it open to atmosphere, but worse, since you would now be be adding a bit of vacuum to the reference side under boost, multiplying the undesired effect.
One fellow I spoke to moved the reference line further from the throttle body towards the turbo and said he had good results, but I havent confirmed this with any testing. Not sure if it would make a large difference or not. But again, It's worth a look.
Great.. so my experiments begin now
How why i dont know.. i am playing with it.. my 2B has a mitsibishi tc05 non wastegated turbo with a max boost of 7psi at pedal to metal situation
