- Thread starter
- #81
I wonder how different the 3b pump and the 2h pump is...hmmmm...
Yea you could use a throttle switch to open the valve up at 3/4-full throttle and close when coming off. I believe the solution is a lot simpler than that though.
Ill be doing some testing today.
Sent with greasy fingers.
There isnt vacuum when boost is present. Once the system goes into positive pressure, it acts like a different animal. The vacuum side and reference side are both pressurized, although, the vacuum side sees a slightly lower boost than the reference side due to the smaller port of the venturi(restricted). The diaphragm spring throttles against this difference in pressure, but still has "less than ideal" resistance at lower revs and while building boost. Equalizing the pressure too much and the spring will throttle the motor eratically, too much difference in pressure results in poor response(too high on the reference side) or the boost throttling the engine(too much on the vacuum side).
There lies the problem I am trying to overcome. Get the pressures to rise closer to the same rate on acceleration, but still be able to hold at constant rpm and boost as well without the surging, and run on when releasing the throttle...
You fellas are starting to paint a better picture of how this works. The Mercedes spring has a different spring rate, it allows the diaphragm to change position quicker allowing us to access more fuel, but after wide open throttle it doesn't snap the diaphragm back in some cases as it seems to be in a state of over fuelling and it acts like a runaway engine. Is this correct?
So,
Initial test.
As a side effect of this, the engine keeps revving until boost drops back down. Makes for interesting road driving. Very similar to a sticky IAC valve on a ford.(ranger owners will know exactly what I'm talking about)
After this short test, it was immediately apparent what power was available and the change to the power curve was unmistakable. To note my fuel is turned way down at the moment and the truck is almost scary fast, compared to yesterday...
You need to read from the beginning of the subject. That has nothing to do with the spring. I installed the spring almost two years ago.
It was tampering with the lines and altering airflow that caused a run-on condition...
Dont mean to be a dick, but really, just go back and read a little bit.
