That is a neat article. Coating the pre cup itself has shown to reduce the power output and increase egts. I talked with a fellow at passanger performance specifically about this and he repeated that he had back to back dynos that proves a noticable drop in power with corisponding increases in egts. I guess the pre cup needs to shed its heat into the fuel mix and directly affects is burn rate or ignition delay or something like that. Insulating the roof of the chamber would be great, but most available ceramics are pretty thin and would not make a massive difference, although would help some. That article talked about an inscert to sheild the chamber and create an insulation barrier... that would be great. It would have to be very tuff to survive in there though. Its a nasty little chamber. I was going to get mine plasma sprayed at a helecopter place where my friend works, but he got fired so no such luck. I was going to add a few mm of ceramics instead of the 5 thou for air brush spray on stuff.
I did port my last cups to reduce outflow pumping losses and help a heavier air fuel mix escape for more power. This was based on the GM IDI diamond cup. EDIT: Here is a pic of the diamond in the middle and the origional on the right. The left one is an aftermarket cup that I forget the name, but it also was used on higher hp version of the same engines. All were used on the gm 6.5 I believe, but with different power ratings.
Here is my cup inside. I blended and widened the opening (black arrows) to lower pumping losses as well as removed all the ceramic coating inside. I also removed material from all of the contact surfaces (white arrows) in order to reduce the thermal transfer of heat from the cup to the head.
Here is the face. Cermics were left intact and the piston opening was not altered much. I did debate drilling a pattern of holes on the block part of the cup to further reduce contact with the cup and the gasket. I decided not to as the gasket is stainless and the face is ceramic coated. One of the drawbacks I read about with the GM IDI cups that were ported (diy ported) was that they ran dirty, even at idle. The thought was that the opening was altered enough so that the air/fuel stream was not properly directed onto the piston allowing it to be deflected upwards properly. It was instead landing on the outer flat edges of the piston and hindering further air fuel mixing and gave it a crappy burn. Mine should keep it centered... hopefully. Many of the diy ported cups had drastically enlarged openings on the piston side. I purposfully tried to avoid that.
My thought was to:
Reatain as much heat in the cup to shed into the air/fuel stream.
Reduce thermal losses into the head.
Allow for a larger air fuel mix to escape from the chamber as fast as possible without altering the incylinder burn dynamics.
My thought was to:
