Unknown history of the truck and/or motor-deceased previous owner. Oil looked good when I drained it, no coolant. Water pump leaks, and, its belt is loose; coolant was very low when I started working on the truck. Fair amount of rust on the air cleaner assembly lid, maybe from the washer nozzle in the hood, could it have found its way into the intake manifold? I have penetrating oil in the spark plug holes, and spark plugs are removed. I tried a bar (clockwise only) on the crank nut, no go. I tried a bit of rocking the 40 in 4th gear, nothing, but I'm no football player. I tried the starter, until a puff of smoke appeared.
What about a lead-shot-hammer on a piece of wood on the flywheel ring gear? Is there a different way of working the flywheel? The crank nut on the front isn't a very rigid set-up in regard to my tools that I am using. When do I pull the oil pan? What would I be looking for?
