- Thread starter
- #41
The cylinder bores appear to be factory size. Also, honing is still evident in the cylinders.
Perhaps when the cracked intake manifold was repaired, the head got a couple of non Toyota exhaust valves. Anyone have recommendations on a valve spring compression tool?
My plan of attack is to get the block out of the truck and start with the block and crankshaft. Because my magnet isn't strong enough to work out all of the lifters, I figure that the camshaft is going to stay put, or should I just pull the crankshaft timing gear? By the way, the crankshaft pulley has quite a bit of lateral movement, that can't be a good sign, right? While I am tool shopping, what do I need for the input shaft bearing? And, is there a method of pulling the block out of the truck without the head on?
