2F Seized
I got my 46mm socket at NAPA also. It was for a impact wrench, very strong. Hope to turn my 78 2F over with it as well to see if it will move too. Mine has been sitting still for 15 years. Did the Murphy (Marvel, oops) Mystery Oil treatment mid last week. Good luck.
I keep checking in on this thread just to see some 2F carnage. I have been rather disappointed so far.
I'm still babying the engine by priming the oil system and adding oil, Marvel Mystery Oil, to the plug holes. I should get a socket in the mail today or as late as Thursday. However, I still am considering oiling of the valve rocker arm train, and getting the camshaft too. I have been focused on rebuilding the carburetor, if for no other reason than it is raining and the truck is outside, I wanted to see the bottom of the float bowl. I got a reasonable quote on a rebuilt 2F from Classic Cruisers, just up the road in Colorado. So I am probably not going to drop in a GM motor, even though I really like the idea of a straight-6 or 305 SBC. I kinda want to see how far I can go with the current 2F even it means rebuilding it part-by-part with donor pieces from the folks at Classic Cruisers (btw, anyone got a set of good manifolds collecting dust).
Those GM engines are blah stick with the 2F. You'll get it.
I removed the pushrods and a few lifters. The camshaft is okay from that limited view. No obvious Carnage.
What is the best method for lifting the head? I want to bang on the pistons with a piece of elm.
if you can get an impact on it the vibration will help free it up has worked for me several times 'worst case is removin g the head and tapping the pistons as mentioned before
im almost 70 and i still just lift the head off its not that heavy ;i get it loose first and just pick it up or a come along to a beam or tree branch and if you want to be fancy an engine crane works well .you will need one any how if you pull the motor
Depends on what's available to ya.
I had no engine hoist nor an overhead beam to mount a come-a-long onto. I'm a pipe fitter and I had pipe stands. I put a stand on either side with a piece of pipe across them. I used a piece of electrical strut with an eye bolt dropped over the rocker studs with fender washers and nuts on each stud. With a shackle, attached a piece of chain from the eye bolt to the pipe across the stands. I cranked up the stands and raised it till I could roll out the vehicle. Then lowered the head onto my pickup and took it to the machine shop.
In place of pipe stands you could use two stacks of concrete blocks and use a wood 4x4 across them. Two ladders and a 4x4 would work also. Just go back and forth and add some cribbing (wood blocks) to either side raising a little at a time. Just a matter of what's available.
When I pulled the head bolts, one was lightly rusted, and two were baked with oil; they were on the side of the manifolds. And when I removed the manifolds, I noticed coolant precipitate from the head gasket in an isolated spot.
So, I decided not to build a gantry. I just went for an affordable 2 ton shop crane. I needed it because the head was not going to separate from the block. Initially, lifting the motor by the head was not enough to undo the head gasket, but with some prying, they managed to finally come apart.
In the photo, you can see that there was gasket material covering some of the passages on the block. What is that all about?
After considerable banging with lumber and a lead-shot hammer, no movement on the crankshaft.
Bigger hammer, or take a straight-edge to the block and head? If it had a gasket failure due to warping, I'll need machining services anyway.
What if this is one of those, oops, the oil pump wasn't running timing checks that I am seeing the wake of? What if the crank bearings are rusted from water from the carb, or from the leaky head gasket?
Is there even such thing as a wrong Land Cruiser '75 2F head gasket?
By the way, I have a used head from an '82 wagon with the intention of using it if I have to switch to flat pistons, or deal with some kind of head damage.
those pistons and bores look good... if you have pulled the distributor and starter, pull the pan and take a look, you are this far in not knowing the history dropping the pan is quick and good insurance...
When I went through the same basic issue on our 72 (sat for 20+ yrs), did the marvel mystery oil for weeks and tried turning the crank nut nothing moved. What eventually worked was to use a pry bar on the flywheel against the bellhousing to free it up.
Once I eventually freed it up and tried to start it, it would only run for 15-45 seconds after stopping like something inside was stopping it. What I would think is that it should be torn down and gone through if you’re dedicated to keeping the engine.
Is everything else that could prevent turning disconnected or in neutral? Starter out? Trans in neutral?
Seems like something external is holding it. Drop the pan.
that is common through out the years i have every head gasket made for an fj40 engine and they varie among the years .not all holes were used for each engine .or it is possible that some one put the wrong gasket on there
