Build 2001 LC HZJ78 AK -RESTORATION- For Overland
@SNLC
Here's the response from PartSouq:
They fit to all
3303060B80 (initial number) then it changes to > 3303060B81 and then to > 3303060B82
it is a 3 same gearboxes, just different revisions, with some sort of improvement
B80 and B81 is discontinued by Toyota
The catalog will only show what it fits. and it shows fits to 7* series land cruisers. does not say it is H151 or H152, as per application it states H150
@SNLC did you find out about the H150 Transmission difference?
Here's the reel time floor sequence. I will keep this, re-used it but for now it's gonna serve as a mock-up for the cabinets
After spending the weekend scrapping my way. I used the 3M pad for sanding and glue the buster to take out the dirt no easy job.
I am not taking out all outside remaining items to prep. No need to do the roof since the Alu cab is on the way!
The differential button test fit that for the Eaton Elockers :)
Hello,
You could get the whole assembly to mount this switch below the steering column. It would look factory.
Just my two cents.
Juan
Hello,
Just my two cents.
Juan
Hi Juan,
Would you have the part# by any chance on most schemas found were not available and all RHD
This is a picture of my Steering assembly I have ordered a new cover steering column #452866092813
There's no hole for the Diff button there?
BTW I am getting an S01 Daikei hub for the new Nardi Wheel :)
Hi Juan,
Hello,
The differential lock switch has its own housing. In-column switches appeared in 2010.
These part numbers are for a SWB, LHD model year 2006 truck. 70 Series changed little over the years. They should fit in your truck.
  1. Panel/Housing: 55432-60090-S7. Light grey.
  2. Mounting bracket 55381-60020.
  3. Screw: 90164-50008.
Hope this helps.
Juan
The locker switch housing doesn't actually mount to the steering column, it is below near your right knee. One screw holds it in place.
Beautiful build by the way. I am impressed with those Rugged Brakes you installed.
Hello,
Hope this helps.
Juan
Hi Juan,
Thank you for pointing this part number. This bolt is directly under the steering column? Should need to get the cover steering column #4528660992B0 from a 2010 then?
@Kroll Thank mate been searching all morning for a 2010 cover column. Then I am not certain I want this under my knee.
Can't wait to try them those will help since the rear brake is not so strong!
Hi Juan,
Hello,
The switch is not part of the steering column. It is to the right.
A steering column cover from 2010 is unlikely to fit. Different design.
This image is from a RHD truck. LHD placement is the mirror image.
Juan
Hello,
Juan
HI @JuanJ Thank you so much this helps a lot and makes me more sens! I will get the cover replacement for 2001 and the Panel/Housing: 55432-60090-S7 but it was BO from Partsoup for now.
Inside the is pretty much scotch brited still some sandblast to in some spot welding for the floor where the previous owner had drilled
Yesterday I had time to manage to install the Superior Handbrake bracket! I also did a fit test of planted brackets for my seat. I will do a mock-up of the driver side to measure the position of a swivel.
Test fitted perfectly for these ones
