1hdt into 1995 US Landcruiser
Is this being done at Sully’s?
This is at my place the engine building room at Solvefunction
Sully has stopped by, showed me a real Landcruiser
Added an an fitting to the valve cover, the old one was broken off.
Took some work but got the pilot bearing out. Bread does not work as well as shop towels.
fuel lines and injectors are all mounted..
thanks @AlbertoSD
Will this slave work with a h150 and a 300mm flywheel?
or do I need the dark red one?
Added an an fitting to the valve cover, the old one was broken off. View attachment 4147377
Took some work but got the pilot bearing out. Bread does not work as well as shop towels.View attachment 4147378
thanks @AlbertoSD View attachment 4147379
Do you have the part number?
You can cross reference part numbers on toyodiy, see what models that part was used in
I had issues with new slave and new master being from different models, want getting full travel at the slave.
I swapped the slave so it was from the same year & model as the master I had used and problem was solved
I think the one I have is 3147060160
its listed for Jan 1990 to March 1990... while 3147060190 is for 1992...
Designed and welded up a turbo support, just for the experience. I definitely want to do more metal work in the future.
bent up parts..
After my first time doing tug with steel.
cooked it!
still does the job, will need a washer added as a spacer. I made it a tad shorter as its easier if its shorter verses it being too tall.
Need some bolts to and injector holders to come in.
Mocking up a big alternator also.
Slot the mounting holes. Looks like you have enough metal there for that.
Nice work Lee 😁
its getting very close to done.
Thats a upgraded alternator from a jag which is 120a i believe, with a smaller pulley from @Delta VS this should make more amps at idle.
Just need smaller alternator belts then those.
Still need a few hoses, like the oil drain, intake to turbo and turbo to air cleaner. Accelerator bracket and a turbo heat shield.
I tried a turbo blanket, but it didnt fit.
