1hdt into 1995 US Landcruiser
Suction power steering hose is done. Thank you George @orangefj45 for getting me this part. Made a bracket to attach to the block
I also did the cad work so I can have a few made, I believe the are discontinued .
lasered out an exhaust gasket, this just gave me a template to cut out with an xacto knife.
chopped off the fart can
Then the bushing was too tall and the pipe was resting on the heat shield. This was going to make a terrible noise.
This is the temp fix, I printed in tpu wide enough to be captured by the bracket on the exhaust. I will be adding a clamp on exhaust hanger in the very back. lowering this give the clearance needed between the body and frame.
motor is in and the starter circuit is working.
I was getting 11.8v through the starter wire with key on until I disconnected the cruise control. which I really do not understand. I am using the black/white wire before the neutral safety switch.
