1hdt into 1995 US Landcruiser
Here is what's happening for fuel, an 10 line to the filter. All mounted to a @deltavs mount.
getting a fitting today to go from the filter to the braided line. It may or may not work, its a slightly different size.
I think the 1hz wiring and the 1hdt are pretty similar
Thats exactly the personal nightmare that made me choose the 1HZ
Wiring like that causes me something bordering on dispair
I think the 1hdt and the 1hz are similar
Not wiring wise....
1HZ requires a lead for fuel selenoid, connections to alternator and for starter and thats it
Not wiring wise....
only difference is if you want to run the factory turbo lights. I'm not running those in my 1hdt swap but it is a ton of work still. there is a engine harness and a engine bay harness. lots of the components are flip flopped as to what harness the wires are on between 1fz and 1hdt.
I made a transfer case shifter gasket and the bolts that hold it down needed bushings. so I printed those too. The material is tpu so its flexible.
The shifter is from a 3fe 80 series. I bent the arm a little in a vise to get the angle right.
Factory turbo light would be cool, but i am missing what ever sensor is used for that.
