- Joined
- Sep 9, 2004
- Threads
- 186
- Messages
- 13,404
- Location
- Boise - Idaho
- Website
- www.snlandcruisers.com
I use a slide hammer to remove stuck injectors. Works everytime.
Cheers
Cheers
My washers got stuck at the bottom. You’re lucky they came out together.Just wanted to share another success story following the steps outlined in this thread! Thank you, OP!
Think it was definitely time for my old injectors
The primary reason I did the swap was in response to excessive white smoke. That was largely resolved following the swap and completely eliminated after I adjusted the injector pump timing to match the FSM spec.
You should post the link where we can purchase itFor anyone who has pulled their hair out trying to remove those crusty injector seat washers from the bottom of the injector bore—when soaking in every penetrating oil known to man has failed, as well as every other fiddly trick, this tool will pop them out in seconds.View attachment 4094248
It’s listed on their website but looks like purchase is available only through a distributor.Here’s info on the manufacturer. View attachment 4094300
