To add to what Stump was saying, if you look at the FSM pics it seems that the cages were made with different markings that would differentiate which side of the cage faces inward toward the diff. It says that for the 40 series, you can look down on the cage holes and see that one side of the hole has a thicker band of metal than the other. In the pics for the 60 series, it says that "a=b", or rather that when you look down on the cage from above at the holes you CANNOT see a difference in width. Rather, the differentiator for 60 series cages is the width of the "chamfer".
I have a 1983 FJ60 and it is as the FSM manual shows ("a=b"). The problem for me is that there are two possible surfaces of the cage that I can see as having the chamfer such that I could be choosing either surface to face inward toward the diff depending on which chamfer I take to be the one the FSM refers to. I am trying to figure out the proper side. Kind of hard to explain in words I guess and I'm not a good drawer.
I will try to show it again by drawing, but I am an not a good artist by any means so please forgive me if it doesn't clear up my description.
