Build 1978 US Market FJ40 Factory Restoration
Interested in the research as well for 78. My Olive 653, has black hood latches & windshield fasteners, which look original?
I also have a chrome bezel which I believe is OEM as well?
Two more devils down, with new hardware welded in place. Eight more to go. When a bolt is stubborn, don’t just keep twisting on it! And if it does snap, don’t drill it out at the current angle of the sun and put a 3/16” bolt through it.
Guys - I need some advice. The quarter panels - while good after re-"lipping" them. Are not straight and WILL require quite a bit, if not considerable filler to get them to something I am proud of. Question: Filler, or replace the quarters with all-new steel? Pros: Clean, straight, correct, little filler. Cons: Time, cost, a ton of work (again), filler. What would you do? As you can see the passenger side is worse than the drive side, but still - both will require quite a bit of filler. This is bugging me enough to ask.
New Steel or else it will bug you forever.
Street or trail rig? Bondo has a habit of popping at the most embarrassing times on trail rigs. :eek:
Because I would rather have the exact pewter color, and I don’t mind/enjoy doing a proper paint job on things. I mean, if a single stage paint lasted 40+ years, I think this epoxy/base clear should last another 40. Ive seen a lot of powder coating that is pretty close to the stock pewter that look amazing however.
