Dirt Dauber Matt
- Thread starter
- #241
Here are a few more "before" pics.
I plan to replace every gasket and seal except the head gasket. It is a good thing because it looks like this thing was leaking from just about every place possible.
The PO said it ran fine, but I think I am going to put the starter back on it and do a compression test on all the cylinders just to double check.
Unfortunately, for old engine "run fine" can be "not run" on next day. It may be a good time to replace the head gasket too as well as valve stem seals (if you will remove the head).
Be honest, I will do same thing as you, if my engine was at running shape.I agree. It would be good to do that and I usually tend to over do things. On this project I am trying to restrain myself from redoing everything and taking 3 years to get this back on the road. It will be disappointing and a little bit of a pain if I have to do the head gasket and valve stems seals after I get everything back together, but it will be doable.
So... all that being said, I think I am going to hold off on those. Things like main seals and clutch will be a major pain later (and I know they need to be replaced now) so I am going to go ahead and do it.
I really do appreciate the advice, and like I said, I agree with you![]()
Awesome!Great progress man! Like that you are focused on getting it running. Some things you can do later. 2f cylinder head removal is easy when in rig. Have done it on my driveway a couple of times. Compression check is a wise move. Do a leakdown test also because it shares some more information than compression. Does not take long.
The carriage bolts in the motor mounts (both passenger side pics) are not correct and not very strong either.
