Build 1965 Seminole Red FJ45 SWB
The pin moved a little more than 1/2” closer to the top of the piston. Here’s a good visual:
Even being longer, the new rods are 235g (1/2 lb) lighter than an average weight stock rod. The range is all over the place from all the years of 2Fs, from the 940s up to the 1030s, tho not that big of a spread from the same motor.
The pistons are 269g (.59 lbs) lighter than stock
Checking the fit of the rings, most of them are around .013 for the top, and .018, which is right in the middle of the factory spec.
We aren’t using the Toyota spec, however. We will calculate these based on the bore, which gives .017 & .021 as the minimum gap. Too big is better than too small here.
That’s exciting to see modern machining being installed in 50+ year old technology
besides alloy pistons that I used, I went stupid and ordered Carrillo rods that totaled 16 pounds lighter then factory
look forward to hearing you engine purrrrrrr
Pistons, rods, bearings assembled before fitting the rings.
I always weigh the pistons and rods separately and mix and match to get the weights close, and then remove material from the rods to match the lightest rod/piston combo. I did the same here, and 5 out of 6 came out to 1285, and one a gram less.
If these were factory cast rods, I’d remove a gram each from the 5, but these are too nice to do that for a one gram difference.
On to the rings…
Rings for factory type builds usually work straight from the package, I usually only have to do this on the custom builds. I use a simple ring grinder to gently file them down:
Then knock down and polish the edges of the cut with a sanding sponge:
Check the fit, and repeat the above as necessary…
Eons later…
Rings on, time to go in…
When you’re tired of fawkin around with the universal ring compressors, you get appropriate sized one piece:
Caps on…
Profit:
This brings back memories at Ramco Piston Ring. I didn’t do any motor building but it was “fun” watching the techs do it. Then they would attempt to blow the motor up to get another test data point 😂.
That’s my job. PawPaw Lockwood won’t ever take it past 3500
Thing of beauty.
What is the factory rod length and the length of the new Carrillos?
Those pistons make me think stroker.
These are about a 1/2” longer, center to center.
Like jewelry! Will torque be about the same?
Thanks! No idea what to expect, it will be interesting to see what happens!
This is good stuff… will final compression be the same?
It will be higher. I’ll do that in the next post.
Here’s a rough compression calculation of a stock 2F. It’s hard to nail down an exact number because head gasket thicknesses vary a little and the combustion chamber volumes vary a little, but this makes the 7.8:1 CR work:
…and here’s the stock 3F/3FE, which is a little higher. It has a shorter stroke and smaller combustion chamber which give it a 300cc smaller displacement.
To calculate the final, we broke out the science lab and went full Mr. Wizard:
Final volume:
Plugging these into the calculator gives a 9.2:1 CR, up from the 7.8 original
Cam installed:
Oil pump in:
Oil pan on (w/stickers soaking):
