Build 1964 FJ45 Short Bed Fixed Top Pickup Restoration
Not that Wilson, the Wilson you never see his face Wilson from Home Improvement
Yes but they don’t shield the firewall they shield the fender in an OEM application where there are heat sensitive items.
They find do anything facing the 40 series firewall.
I’m also wanting to Cover up all of the black plugs and randomness from years I’ll of drilling
Hello,
It makes sense.
Drilling holes in the firewall or elsewhere is too strong a temptation to resist for many owners.
For what it is worth, FZJ7x trucks have both exhaust manifold plates and heat insulation in the firewall.
Juan
Yanked the hump and fuel tank out today because we got a lot of noise and a leak somewhere.
I discovered this stuff that Can Am uses on the bottom of the bed of my UTV and found it’s designed for the elements unlike most stick on heat stuff. It also does not roll and mold like noico or dynamat so you have to piece it together on odd shaped stuff
I added a SOR gasket. I love these things and then added the extra to the bottom of the tank to give it some extra cushion between it and the tub
Do you have a pic or two of how the TC high/N/low lever mounts to the side of the tranny? My junior high shop class mount broke on my ‘65 so need to come up with a non-broken solution.
This transfer is nothing like the one you have. It’s a 4 speed and split case from an FJ60
Find used stuff. I bought this set from @orangefj45
We have lots of linkage parts along with everything else for transmissions and transfer cases.
Great work bud, looks good!
Georg @ Valley Hybrids @ Cruiser Brothers
Shop 209-475-8808
Sales@valleyhybrids.com
I have gotten a few messages about this so I just want to clear the air. I think I have made it clear that the truck will not be coming back to Florida - I simply do not have the space with the other trucks in my possession. A couple of people have inquired about when I would be posting a "for sale ad." That will not happen. I am currently working on the BAT listing and @wngrog will take the photos once the paint is dry. The truck can be bought now - in progress - or wait until the BAT auction. Happy to discuss more with interested parties. There is a selfish part of me that just wants to auction it off. However, I can also appreciate that the next owner might want to make some choices in how the truck comes back together.
The in-tank pump was screaming when I picked the truck up and I was convinced the tank needed to be moved out of the cab.
So I made a plan to put a fuel cell into the frame.
Man A Fre sells a totally pimp tank for a 40 and I talked to Rick and he thought it would work if I pulled the spare tire support out
Turns out, once I pulled the tank out and lined the area between the tank and tub and added soft lines the noise went completely away.
So….if anyone wants a great deal on a Man A Fre tank, hit me up.
Sorry John.
Sorry John.
Im interested in the Man A Fre tank if its still available
