1963 fj40 distributor
Colors do
I just recently bought a 1963 fj40 and the distributor mechanical advance doesn’t seem to be working. I have been looking to replace the distributor but I’m having a hard time finding a replacement. If anyone has any experience with this I would love some guidance. Thank you!
The Delco my 72 came with in 82 finally wore out. I bought the chinesium Delco on Amoron $130. Swapped over my old Toyota drive gear. Used my old Delco cap and expensive spark wires. Work great for about a week, then the china points arm bent. Put in my old real Delco, been running great ever since. Love the straight mechanical advance.
I just got back from driving my '70 BMW 2002 after replacing the condenser. It crapped out 5 miles from home on July 4th weekend, first time it's left me stranded since I bought it 6 years ago. I'd replaced the condenser with a brand new Bosch unit when rebuilding the engine and distributor... which was built in Turkey? China? Anyway I bought a NOS German one and it's running like a top again. These old things like what they like, I guess!
Have this on my ‘63 45 (the motor is a ‘64 1F), also get the clamp noted in the text.
Oftentimes, especially with the older Landcruisers, simply taking it apart and cleaning it up works wonders. Might help to show us what dizzy you have. Does the vacuum advance work? Why do you think the mechanical advance does not work?
Cars are only as reliable as their crapiest part. You can't make chicken salad out of chicken s***e. Cruisers (and old Bimmers) developed their reputation for reliably using their factory parts. Throw Chinese (or Turkish) into the mix and you've got Chinese reliability.
Yup. The supply chain has obviously globalized so much since these things were built. I'll gladly refurbish / rebuild a factory part over buying new, if I can.
For what it's worth, the Bosch condensers have a terrible rep in the BMW community, with some brand new out of the box parts failing after 5-10 miles of use!
I think there are places that rebuild dizzy's. Springs and weights were available for tweaking advance curves. Chevy/Toyota way back in the day were closely related.
Chinesium isn't my first choice, but then again sometimes they get stuff right.
When I would twist the rotor while it was in the car It would just twist and stay put instead of springing back.
These are a great option and what we use when we need a distributor for an older cruiser.
That's not enough of a problem to toss out a dizzy. Would it be so hard to post a pic of your dizzy? You should have one of the '69-and-earlier vac advance dizzys. I really like those, super simple. Probably some brakeclean and PB blaster would fix a sticky advancer mechanism where it sits, but you really should pull it out, take it apart (just a little), look for anything broken or stuck, clean it all up and put it back together.
I’ll post some pictures as soon as I can but it does not have vacuum advance. I already took it apart and cleaned it but I still had the same issue.
As a Turk, I take offense to this sentiment. Toyota’s most advanced European plant is in Turkey, as well as key supply chains for service parts support.
No offence intended to any nationality. Merely saying that most cars run best with original equipment. The original post referred to a BMW part from Turkey. We should always look deeper into statements before jumping to offence. This is why we're where we are today.
I didn't know your grew up in Turkey, I thought you were from America. One of my best friends is married to a Coptic Turk from Ararat. Where did you grow up?
Quality control world wide is slipping IMHO. New and improved is now cheaper and faster produced - testing? we don't do no stinking testing, that's your job after you buy it and the warrantee expired the second you opened the box.
I had my dizzy rebuilt by Advanced Distributors. https://www.advanceddistributors.com/
Good guy and did a beautiful job of fully rebuilding the unit including the vacuum advance diaphragm. A good way to go if you want to keep it original. If not then definitely grab a new OEM unit linked in posts above. You will have to change from a hard line to rubber line though.
Also, as a data point. This was back in 2019 and I paid about $250-300, but I cant remember exactly and it took a few weeks to get back.
