Jeez. Do the tire weights clear?
I suppose you could always use stick-on weights (I do - for other reasons). Or maybe a 0.25" spacer.
pretty sure that the weights would NOT be a problem, they would be further out.
So, 67, I'm assuming those same rims that barely fit your 25 are fine on your 45, no?
If so, MOT, would you mind shooting me a PM? I'd like to arrange to get a set, please.
wow from the outside they look nearly identical....just need to cut out a hole to match oem 25 rims![]()
Well I measured a FJ25 rim today and it didn't have as much back spacing as these new 16" rims. Kinda hard to measure with a tire mounted but as best I could tell it's only 2 7/8" which is close to a 1/2" lessI guess we need to know what the back spacing is of Archies's wheels. Of course someone could always pay to get one to the US to see if the new one by chance would work.
PS I measured it by using a file that reached across from one edge of the rim to the other edge. Then measured to the center by the lug nut holes. Then flipped the file and measured again in case the file wasn't straight. Came out the same both times.
back spacing measurement are:
OEM 16" ...............2 7/8" short
NON USA 16" ........3 1/4" long
approx., 7/16" long (deeper)
Looks like our measuerments were pretty close. Lucky the steering arms aren't that close on the stock 25 wheels. I wonder if the disk brake 15" wheels back spacing is the same. The 1/2" extra clearance on the 16" is enough to make them fit. A 1/8" wheel spacer probably wouldn't hurt. I know with the 15" disk brake wheels your were going to need more back spacing than I would feel safe using.
I wouldn't mind haven't a set of these for my FJ45LPB. Mot how many can you get? Cost? Anybody want to buy a nice set of 16" split rims?
I think I just run the stock FJ25 wheels on my FJ25s![]()
I just checked mine and they have got OEM 16" backspacing just like original FJ25 wheel, also mine are rivited like OEM and looks like the new ones Sean got are welded.![]()
Could you make a 1/4 inch spacer plate to improve the clearance.
I'm really sorry to be telling this to you guys, but...
I've contacted two separate Toyota Parts branches just to make sure, but the wheel(s) that Sean got has/have been discontinued!!!![]()
Useless SirWe need more MOT's around the world![]()
"only if you find a dealer who stored them,"
are those the 22 Series ?
http://www.stocktonwheel.com/heavy_duty_wheels.php
http://www.stocktonwheel.com/catalog.pdf
not a bad price 107 for the rims...how much less was it in bare metal?
