Hello
@Otamiway
I just installed this excellent product from
@Photoman he was super help full with all my questions and was a perfect fit.
I have a question that maybe som one can answer me.
Installed is the 150Amp alternator from a Sequoa, I have a dual battery system (2 yellow top Optima) controle by a Bluesea AL-MRC (highly recommended). I also have a Ironman dual battery display that shows me the volts for the batteries, its a simple one so its just lights with a specific voltage under each one.
Here goes my question. With the stock alternator the voltage was always over 14.1 volts, with normal driving and night driving with my lights on, it rearley went under 14.1 volts during normal car use.
Now with the 150Amp alternator when i start the car its over 14.1 Volt and then after a couple of minutes of driving around (the car already warm and normal idle) not the voltage stays at 13.8 Volts, unless im cruising at about 3000RMP. but its mostly at 13.8Volt
Funny thing is during the first 3 min of the car when i turn it on, on idle (700RPM) it sits over 14.1 volt and then after that time at the same idle not it sits on 13.8Volt
I was reading that this Alternators have a voltage regulator that lets it give the voltage the batteries actually need, but it seams odd since the old one was just at full blast all the time, maybe its just a better technology because the symptom does seem like a switch changes from over 14.1 to 13.8 Volt.
Im just concerned that is not that when the Alternator gets warm it starts lacking in performance.
ALSO, If any one has any question on the install or want to see pics of the set up im more than happy to post them, I also put a 150amp relay on the instal for security and the car is supercharged to i can show how to fill everything in the tight space.
